PCV map on 2017+ - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 09-05-2018, 11:30 AM Thread Starter
basshead's Avatar
PCV map on 2017+
I have an Arrow collector coming my way and debating if I'll get the PCV to maximize the performance (I'm more after sound than performance). I see that there's map available for the 14 on the Arrow website, can I use it with my 18?
Shop with dyno is the only other solution or there's other map to download that I didn't find.
2018 Yellow DL1000
basshead is offline
post #2 of 13 Old 09-05-2018, 10:17 PM Thread Starter
basshead's Avatar
Well I've went with the Booster Plug, it should prevent the bike to run too lean with the new collector.
2018 Yellow DL1000
basshead is offline
post #3 of 13 Old 11-22-2018, 02:09 AM
Please let us know how the booster plug work out. I’m interested in finding out about your results- how the bike runs with setup, fuel consumption, popping on decelerations with after market can...
fob99705 is offline
post #4 of 13 Old 11-22-2018, 03:54 AM Thread Starter
basshead's Avatar
I had to remove it when the temperature started to fall under 10c (50f). The bike would stall when cold and my fuel consumption was about the same as my truck on the highway (10.5l/100km or 22.4mpg) according to the computer... after removing it the stalling problem was gone and fuel consumption was much better but still higher than when warmer but this is normal I believe.
I sent an email to Booster plug and they said it was not their product at fault and that the bike must had other issues. They mentioned the TPS, but never managed to check it before storing it for winter.
Sent from my SM-N950W using Tapatalk
2018 Yellow DL1000
basshead is offline
post #5 of 13 Old 11-22-2018, 10:04 AM
Administrator
My guess is on the booster plug, highly doubtful anything wrong with your Strom. The only true solution for fuel management is a PCV, although I have doubts you are even needing that on your bike. You are just not going to squeeze any realistic increase in HP and torque on the 650's with an exhaust system, having them sound appropriate and losing a bit of weight are the real advantages.
2015 DL650 XT "Fred"
1997 Honda Valkyrie 1500 custom “Fiona”
post #6 of 13 Old 11-22-2018, 12:45 PM
blaustrom's Avatar
Big-B, I think he has a V2.
Basshead, I am also running a "Boosterplug" and on my last trip to the peep show in Maine we had real cold mornings, certainly lower than 10*C. I did not have any stalling problems. Did not monitor the fuel consumption but nothing indicated that there was anything seriously wrong. But we did not do short trip type riding, so basically just a couple of warmups per day at the most. Mine is a 2014 V2, about 40k.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #7 of 13 Old 11-23-2018, 11:53 PM
Administrator
Yup my bad, in that case I highly recommend a PCV over anything else.
post #8 of 13 Old 11-24-2018, 08:32 PM
Don't waste your money on a PCV. Get a PCFC for a lot less and it will do EXACTLY the same thing. I cannot for the life of me understand why people still buy PCVs or any other specific PC product when we have no use at all for most of the expensive features they have. All we want is fuel adjustability and the PCFC gives you that for a lot less money. It uses the very same maps that the others do.
bobbyvstrom is offline
post #9 of 13 Old 11-28-2018, 01:49 AM
D.T.'s Avatar
PC5 has ignition adjustments also.
Booster Plug??
https://www.boosterplug.com/shop/boo...i-dl-381p.html
$160 to add a 10k resistor to the IAT?
2005 Suzuki SV1000R 80K miles, 2012 Suzuki DL650AL2, over 40k miles already!
D.T. is online now
post #10 of 13 Old 04-06-2019, 08:24 PM
hybridgsxr's Avatar
Do any of you guys have a PCV map you would like to share?
Sent from my SM-G955U using Tapatalk
hybridgsxr is offline
NEVA 2017 - Poconos adventure - Official thread BigMan73 North East (Mid Atlantic) 290 04-18-2019 04:29 PM
***Opinions of other 2017 ADV bikes - Stop hating on the 650xt HanSolo DL650A - 2017+ 9 06-24-2018 03:14 PM
Spring 2017 - Romney, West Virginia - May 5 - May 7, 2017 Dirt_Dad Events 245 10-15-2017 11:28 AM
