Snappy throttle (on/off) - Page 6 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 30Likes
post #51 of 63 Old 09-16-2019, 04:23 PM
Finally, it seems I found my solution! The Suzuki service mechanic suggesteď me to turn Traction Control Off because that interfere with gnition... as I feel it helped!
We could also tune the cable slack a bit but during the next service it will be adjusted.
TPS was checked via computer diagnostics and that was good.
Jengo is offline
post #52 of 63 Old 09-25-2019, 04:25 AM
bighammer's Avatar
Am I reading this right that you are checking the TPS adjustment with the engine off??
2018 Flee-Strom 1000XT
bighammer is offline
post #53 of 63 Old 09-25-2019, 07:13 AM
Good question, didnt seem to specify in my service manual.
2016 DL1000 ABS
ERockJL is offline
post #54 of 63 Old 09-25-2019, 09:14 AM
Bazooka Joe's Avatar
You will adjust the TPS with engine not running, but with the ignition key turned on.
18 1000 XT yellow. Bunch of goodies installed.
2015 Yamaha WR250F- Street plated woods bike
Previous rides- about 25 different bikes, mostly dirtbikes.
Bazooka Joe is offline
post #55 of 63 Old 09-25-2019, 05:52 PM
bighammer's Avatar
Interesting.... I'm curious of the source of these directions, and sort of wonder if an important step was left out.
The procedure for the SV650 is very similar, but with a warmed up and running engine. (shut off to jump wires for dealer mode) While getting engine to normal operating temp, adjust idle to 1200 RPM. The "-" sign should be in the center of the display. Advance the throttle very slowly, and it should jump to the top at 1450-1500 RPM. The 3 bikes I adjusted were all at 3000+. back off the screws a bit on the TPS
At that point it was a T25 security bit to back off the screws so the TPS (sensor with 2 screws, one in an elongated hole) can be moved with some resistance. It's sensitive and you have to move it in very small increments, sort of a trial and error check, re check.
I haven't checked my Strom yet, but I will be curious to see what it does running vs stopped.
post #56 of 63 Old 09-26-2019, 09:18 AM
Bighammer-
Hmmm,,, I guess I dunno if "engine off" is correct and I might have done it incorrectly. It seemed logical to set with the engine off, so that's what I did. I do know my bike sure runs much better after the adjustment per the method I used.
post #57 of 63 Old 09-26-2019, 09:34 AM
the plot thickens.
My service manual would suggest but doesnt explicitly say engine off. However, i have read other forums/models where they were setting the TPS at different rpm's.
2016 DL1000 ABS
ERockJL is offline
post #58 of 63 Old 09-26-2019, 01:44 PM
This is an interesting discussion.
For controlling idle rpm, does anyone know if the Vee 2 & 3 have a IAC (idle air control) valve? As opposed to an actuator which physically opens the butterflies? IAC circuit bypasses the butterfly and is most common in automotive systems.
If these bikes have an IAC, then the butterflies will be completely closed whether the engine is running or stalled, and the TPS reading should be the same in either situation.
post #59 of 63 Old 09-26-2019, 04:16 PM
I have also read that (during throttle movement) the rpm when the middle dash in '-C00' changes to high counts as well. DL1000 shall be around 1200-1600rpm ideally, 650's are higher a bit but defenitely not as high as ~3500rpm.
This transition probably makes changes to engine control that makes the throttle reaction not so smooth at low rpm:s in my reading.
To be able to check this transition you have to have the engine running. This can be a kind of a fine tuning after the getting to the starting point (-C00).
Also read that TPS should not be sensitive to temperature. So does not matter whether the engine is hot (running) or not.
When the TPS gets sensitive to temp. it's not working correctly anymore.
Without practical experience I do not want to say the truth, just tried to summarize my knowledge I read about this topic that I'm also interested in.
Jengo is offline
post #60 of 63 Old 09-29-2019, 03:46 PM
Thanks, I turned off TC and it did help the snappiness throttling from idle.. kinda sucks you have to lose TC to smooth out the throttle
Jengo likes this.
Billyn is offline
I'm having trouble removing the throttle grip BuckyD DL650 and DL650A - 2004 to 2011 2 08-19-2014 12:29 PM
Throttle Sticking bigpee DL650 and DL650A - 2004 to 2011 13 03-25-2009 03:21 PM
Crunchy throttle after heated grip installation bunner bob General V-Strom Discussion 3 11-23-2007 02:11 PM
