Snappy throttle (on/off) - Page 5 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 40Likes
post #41 of 74 Old 07-17-2019, 12:08 PM
BJ, the tool is Suzuki part No.09930-82720.
It's a small 2-position toggle switch with a 5" wire harness that terminates in a connector which is the mate to the underseat Dealer Mode connector. One could easily fabricate one with a small electronic supply store-bought 2-position toggle switch, some wire, and a terminal block w/terminals from Corsa Technica.com. But I'd rather just have one sent to me from Amazon.com for approx $20. This is the tool shown in the factory service manual.
There is a similar tool shown in the manual for ABS diagnosis, but they aren't the same.
My receipt for the tool shows total price as $19.95, and the supplier, through Amazon was Everett Powersports (425)212-2111 EverettPowersports.com
MAZ4ME is offline
post #42 of 74 Old 09-06-2019, 02:30 PM
Originally Posted by MAZ4ME View Post
I raised the tank, and using a T25 Tamperproof Torx bit, 1/4" drive ratchet and locking 6" extension, adjusted my TPS to spec--the top of the "C".
Which part is it you are adjusting - Is it obvious when the tank is lifted?
Anyone knows how the DC650A 2017 will indicate a correctly adjusted TPS?
Regards, Lars.
bonne is offline
post #43 of 74 Old 09-06-2019, 08:44 PM
Bully's Avatar
Hi All,
Attempting to check TPS using the above instructions.
I've jumped the diagnostic plug and l have "c00" displayed on the odometer but there is no hyphen in the lower or upper position at the back of the "c"
Is my TPS set correctly or do I need to adjust the position of the TPS screw for the hyphen to appear? Or have I been a bonehead and missed some step along the way?
Your help would be greatly appreciated.
Bully is offline
post #44 of 74 Old 09-07-2019, 03:24 PM
Same thing to me. No dash next to c00. Would appreciate if someone gave us an idea what's wrong. / DL1000A 2018
Thanks!
Jengo is offline
post #45 of 74 Old 09-07-2019, 04:33 PM
blaustrom's Avatar
Originally Posted by Bully View Post
… I've jumped the diagnostic plug and l have "c00" displayed on the odometer but there is no hyphen in the lower or upper position at the back of the "c" ....
Thanks!
Post a picture of what you are seeing.
And check the service manual for your model as to what the TPS sensor setting procedure is. Maybe different than the reference postings.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #46 of 74 Old 09-08-2019, 04:58 AM
Dear Bully,
Thanks for your reply!
I have swithed to dealer mode, turned the ignition on. See images attached.
I do not have service manual, so could not check the TPS setting procedure
Any idea what I did wrong?
Jengo is offline
post #47 of 74 Old 09-08-2019, 08:05 AM
Bazooka Joe's Avatar
Jengo,
You are doing it correctly.
I wonder if the USA models are different. My bike had the little mark to the left of the "c00", meaning it looked like _c00 and I adjusted to -c00.
I wish that I knew more to tell you.
18 1000 XT yellow. Bunch of goodies installed.
2015 Yamaha WR250F- Street plated woods bike
Previous rides- about 25 different bikes, mostly dirtbikes.
Bazooka Joe is online now
post #48 of 74 Old 09-08-2019, 05:22 PM
Hey Bazooka,
Thank you for the confirmation!
My bike's 6000km service is about to happen.
I will ask the mechanic about it! Would be nice to make sure that this setting is corect (if not then adjust it) because at low speed (like in a roundabout) I don't feel the engine-throttle reaction comfortable... :-(
I can live with it, but as I read above it could be better :-)
Jengo is offline
post #49 of 74 Old 09-08-2019, 09:34 PM
Brockie's Avatar
Try removing all of the slack out of the throttle cables. I find that cable slack as per the manual accentuates that abrupt on/off jerkiness.
Brockie is offline
post #50 of 74 Old 09-09-2019, 07:12 AM
Throttle cable slack is a good point that I am aware of. Unfortunately I couldn't remove it completely because no more adjustment can be done at the throttle side, so this is also one task to do during the service... Thanks Brockie!
Jengo is offline
I'm having trouble removing the throttle grip BuckyD DL650 and DL650A - 2004 to 2011 2 08-19-2014 01:29 PM
Throttle Sticking bigpee DL650 and DL650A - 2004 to 2011 13 03-25-2009 04:21 PM
Crunchy throttle after heated grip installation bunner bob General V-Strom Discussion 3 11-23-2007 03:11 PM
