Snappy throttle (on/off) - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 40Likes
post #11 of 74 Old 09-05-2018, 11:08 PM Thread Starter
basshead's Avatar
Ok so after reading and watching many reviews I've decided to give the Booster Plug a try.
2018 Yellow DL1000
basshead is offline
post #12 of 74 Old 09-12-2018, 12:20 PM Thread Starter
basshead's Avatar
Got the Booster Plug yesterday and installed it this morning.
Here's what the site say it will do and my observations so far after my morning commute:
Improved and softer throttle response when rolling the throttle on-off.
yes, I'll admit the bike is much smoother when you start in first, but the roll-off (my primary complaint) is still very noticeable and not sure if there's any change
Enrichment of Air/Fuel mixture when you open the throttle will improve acceleration.
only did one real pull and it could be placebo effect, but it did feel quicker
Remove the Jerky low speed running that is typical for modern lean burn engines.
I can now get down to 2100 rpm and the bike with start to pull without issue, before under 2500 was very jerky
Stronger and more reliable Idle.
it does feel smoother
Reduced Puffing in your aftermarket exhaust on engine braking.
Nope, same as before
Is this little thing worth it at 160$? I'd say yes, it didn't solve my issue, but I still like how the bike feel and respond now.
Next change will be to try to completely remove the slack in the throttle, now I'm within the recommend spec, but will try to remove more and make sure moving the steering doesn't affect it.
Spec, Webfors, erci and 1 others like this.
2018 Yellow DL1000
basshead is offline
post #13 of 74 Old 09-12-2018, 11:22 PM
blaustrom's Avatar
Booster Plug: Very similar to my findings. Still pops into the exhaust.
Removing the slack in your throttle is a must to reduce the jerking.
Big B likes this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #14 of 74 Old 10-03-2018, 10:18 PM
Bully's Avatar
I've just installed the G2 Throttle Tamer on my 2017 Vee. It's solved 85% of my problems regarding the snatchy throttle, highway speeds are easier to hold as a bonus. I can live with the throttle now, money well spent!
Bully is offline
post #15 of 74 Old 10-05-2018, 12:41 PM Thread Starter
basshead's Avatar
Just got my G2 tamer this morning. Hope it help lol
Sent from my SM-N950W using Tapatalk
2018 Yellow DL1000
basshead is offline
post #16 of 74 Old 10-10-2018, 09:27 PM Thread Starter
basshead's Avatar
love the G2, it removed the instant on and gave me extra room before switching to off. Now I can take that ramp and slightly adjust my speed without having to slip the clutch or change gear.
Also I got myself a pair of battery heated gloves, so far it made a huge difference when stuck in traffic keeping my left fingers warm, now I just need winter tires, but my wife won't let me (it's a good thing)
Spec likes this.
2018 Yellow DL1000
basshead is offline
post #17 of 74 Old 10-10-2018, 11:47 PM
Basshead, allow me to suggest something that may improve your throttle response.
Ive recently done this procedure on a '16 GSX-S1000, my '14 Vstrom1000. a '07 GSXR-750, and a '14 Vstrom650.
Check your Throttle Position Sensor setting.
This is REAL simple and quick and will cost you nothing to check. Adjust your throttle cable slack to 1/8" rotational free play at the grip.
1) Remove the seat and locate the white 6-pin Dealer Mode Connector
2) Remove the Dealer mode Connector cap and set aside
3) Dealer Mode Connector terminal end facing you with the cap latch on top, jumper the white/red and black/white wire terminals at the right side of the connector together with an unbent small paper clip. These terminals are stacked one over the other.
4) Turn ignition switch to the "ON" position, engine off
5) Look at your trip odometer in your gauge cluster--it will have switched from tripmeter to code reader. If there is no diagnostic trouble code you will see "C00". If your TPS adjustment is correct, you will see a hyphen just to the left of the "C", as in "-C" On the Vstrom the hyphen may be inline with the top of the "C". If the hyphen is either at the bottom of the "C:, or above the "C", the TPS needs adjustment.
My friend's Vstrom 650 was right on the money.
My Vstrom1000 was at the bottom of the C but had no drivability issues. I raised the tank, and using a T25 Tamperproof Torx bit, 1/4" drive ratchet and locking 6" extension, adjusted my TPS to spec--the top of the "C".
It ran great before, but is outstanding now. Smoother cold running, better throttle response, more power everywhere.
The GSX-R750 was at the bottom of the C. Same story, the owner reports smoother on-off-n throttle transitions, smoother and quicker response.
The real deal was a friend's GSX-S1000. For a year and a half he complained of buck on off-on throttle transitions, hesitations during low-speed maneuvers. He installed a G2 Throttle Tamer, only slightly better. He had his ECU reprogrammed 3 times, $$$$, and still didnt run right. He seriously considered selling the bike.
I did the TPS check--and it was waaay off, at the bottom. I adjusted the TPS...AND FIXED Totally different bike now and he is thrilled.
I did purchase the Suzuki Tool to do this job, makes it quicker and easier. Part # 09930-82720, was $20 shipped. But a paper clip will do.
The lesson here is twofold: Never assume the factory settings are correct, and dont do performance mods trying to correct drivability issues until you make sure the specified settings are right.
Big B, Bazooka Joe, dravnx and 3 others like this.
MAZ4ME is offline
post #18 of 74 Old 10-11-2018, 03:33 PM
blaustrom's Avatar
… My Vstrom1000 was at the bottom of the C but had no drivability issues. I raised the tank, and using a T25 Tamperproof Torx bit, 1/4" drive ratchet and locking 6" extension, adjusted my TPS to spec--the top of the "C". …
Can you please confirm, did you adjust to:
--"C"
or
"C" .. meaning on top
rather than in the center?
Blau2 2014 DL1000A
post #19 of 74 Old 10-11-2018, 07:45 PM
Blau, on the GSXR-750 the hyphen was adjusted to the -C, center of back of C.
The GSX-S1000 was likewise adjusted to the -C.
My '14 Vstrom1000 does not adjust to the center of the C as in the above 2. It adjusts correctly with the hyphen even with the top top of the C (My puter wont do that, sorry. Picture these 2 apostrophes as a singly hyphen ""C)
There are only 3 readings possible. 1) _C, 2) -C, and 3) ''C
The correct setting is "C for the '14 DL1000.
In all cases, when the hyphen is above the C or at the bottom of the C the setting is incorrect, and this TPS setting will have the ECU running lean at all throttle positions. The TPS is set at closed throttle, but its setting affects the whole range of throttle rotation.
MAZ4ME is offline
post #20 of 74 Old 10-11-2018, 10:40 PM
America First's Avatar
I'm a newbie and have also felt a bit of a snappy throttle on my 2017 V-Strom DL650, but I thought it was me not having great throttle control yet. I'll have to pay attention to it and see if it's me or the bike.
America First is offline
I'm having trouble removing the throttle grip BuckyD DL650 and DL650A - 2004 to 2011 2 08-19-2014 01:29 PM
Throttle Sticking bigpee DL650 and DL650A - 2004 to 2011 13 03-25-2009 04:21 PM
Crunchy throttle after heated grip installation bunner bob General V-Strom Discussion 3 11-23-2007 03:11 PM
