ABS Disconnect??? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
  • 2 Post By Spec
  • 1 Post By Motor7
  • 3 Post By Old Codger
post #1 of 9 Old 08-08-2018, 11:26 PM Thread Starter
ABS Disconnect???
Can I get some guidence on disconnecting rear ABS... learned the hard way that I need to be able to lock rear up when coming in hot on gravel back roads... can I simply zip tie sensor out of the way. Is there system issues which make this ill advised??? Two more days of NV back roads and ABS is not safe... thanks for your help!
ChazEd is offline
post #2 of 9 Old 08-09-2018, 01:59 AM
Rolex's Avatar
This works on the earlier bikes, put the bike on the stand, start the motor, select second gear and spin the rear wheel, the system disables it's self.
You will need to do this every time you turn the ignition on and off.
I put a switch in my V2, I'm not sure if your system is the same ?
If you pull the rear sensor you will also loose TC, (I have my TC off 24/7 anyway)
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #3 of 9 Old 08-09-2018, 10:43 AM
erci's Avatar
I might be reading it wrong, but I think ChazEd is asking specifically about rear wheel.. keeping front wheel ABS active.
That is the ultimate dirt setup, but unfortunately I don't think anyone has achieved this yet.
Otherwise, Rolex's approach is awesome (disable/enable entire ABS system on the fly).
erci is offline
post #4 of 9 Old 11-11-2018, 12:27 AM
Does anyone know if this works on a 2018 1000?
Justin1000 is offline
post #5 of 9 Old 11-11-2018, 09:15 AM
Spec's Avatar
Not being a smartazz but its not a dirt bike. If you're going so fast you have to brake slide around corners turning off the ABS is only going to allow you to crash harder!
Once 500 lbs of bike gets out of shape on dirt you're just along for the ride. Especially on a pretend "Adventure bike" like the V-Strom.
bighammer and Motor7 like this.
Spec is offline
post #6 of 9 Old 11-11-2018, 09:34 AM
Motor7's Avatar
I actually like having the rear ABS on gravel roads. Like you, coming in hot to an unknown turn can cause some clenching of certain body parts. When that has happened I just let the rear go into full ABS while doing a threshold brake(not allowing abs to engage) on the front. I have found that this stops me quicker than if I turn off the ABS completely and slide. As Spec mentioned, once these pigs start to slide it's like you are on an iced over duck pond. The rear ABS modulating helps me concentrate on the front brake and steering. Anyway, try it and see if it works for you and it's easy to practice on a nice straight section of gravel. You could even drop some small cones, maintain a set speed before applying brakes at the first cone, then mark/measure the stopping distance in each "mode" of braking with a second cone.
Big B likes this.
'15 DL650XT
Motor7 is offline
post #7 of 9 Old 11-11-2018, 08:01 PM
After being a desert rider for 30 years I agree its not a Dirt bike....Might be a dirt road bike ????...
bighammer, Spec and Motor7 like this.
Norm
Riding for 60 years
Current Rides
2018 Suzuki DL 1000 ADV.
2010 Yamaha XT250
2005 BMW R 1200 RT Gone
2011 Suzuki DL650 Gone
Plus 43 other Dirt and Street Bikes from AJS to Harley in my past...
Old Codger is offline
post #8 of 9 Old 11-11-2018, 09:31 PM
I was kinda done with this thread, however it brings back some thoughts from my distant past. My favorite dirt bike was a Honda CR 500 I had 2 of them, favorite street bike bike was a BMW R1200RT. Looking at BMW MOA Mag. a couple of yrs. ago there is a New BMW ADV GS UP Sidedown in a rock pile with all the lasted GPS and Bags all bent up... W'T.F. BUY THE BIKE THAT FITS THE JOB....
Norm
Riding for 60 years
Current Rides
2010 Yamaha XT250
post #9 of 9 Old 11-20-2018, 02:25 PM Thread Starter
Got it.... Not a dirt bike.... I'll refrain for pushing my skills and thrills until I can fill the garage with specialized toys. CE
ChazEd is offline
