How to remove upper triple tree clamp for cable re routing? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 10Likes
post #1 of 15 Old 06-04-2018, 06:50 PM Thread Starter
dwayneh's Avatar
As the title says; what EXACTLY do I need to do to remove the upper triple tree clamp? Remove the center bolt (which I am to re-toque to 65 ft/lbs???). I am also to loosen off the two Allen bolts one for each side of the clamp?? Then I just move the BRAKE hoses, or only one? Anything else?
Current ride:
2018 V Strom 1000 XT
Past rides:
Honda NX 125 enduro, Yamaha V-Star 650, Suzuki 1500 Intruder,
BMW R1150R, BMW K1200S,
Triumph Sprint ST 1050 (Caspian Blue), Triumph Sprint ST 1050 (Silver)
dwayneh is offline
post #2 of 15 Old 06-04-2018, 08:44 PM
You can loosen the pinch bolts and slide the fork tubes down without messing with the triple tree. Just make sure the front of the bike is properly supported.
DesertBike and Hatchi like this.
wingstrom is offline
post #3 of 15 Old 06-04-2018, 08:45 PM Thread Starter
dwayneh's Avatar
THAT! Is an awesome idea! Thank you for that.
wingstrom and Hatchi like this.
Current ride:
Past rides:
dwayneh is offline
post #4 of 15 Old 06-04-2018, 11:05 PM
On my 800ST BMW i moved the throttle assy and made the adjustments. On my Wee's i just loosened the cables and added the bar risers, no sweat.
You can move the cabling without messing with the triple tree. At least I've been lucky so far.
post #5 of 15 Old 06-04-2018, 11:07 PM Thread Starter
dwayneh's Avatar
Loosened the cables? By that do you mean removing the hoses from the clamps holding it to the frame?
Current ride:
Past rides:
dwayneh is offline
post #6 of 15 Old 06-04-2018, 11:27 PM
That's what i did on my efforts. On the BMW I had to reroute the cables out of the wire holders. On the Wee I was able to stretch things a bit to make a bar riser work.
The cable holders are nice but may give you some slack out of the cable guides.
it may not be the best of the choices but in my case it worked.
What exactly are you working with?
post #7 of 15 Old 06-05-2018, 03:41 AM Thread Starter
dwayneh's Avatar
Rox risers 50mm adjustable.
Current ride:
Past rides:
dwayneh is offline
post #8 of 15 Old 06-05-2018, 09:16 AM
blaustrom's Avatar
To remove the top tripple tree I think is the easiest. As long as you have the tools to remove the rear axle you can break the center nut. Can't remember the socket size, may be 30mm?
Whilst you are in there check the steering heard bearing for tightness (unless the bike is pretty new). They are likely a little loose.
If you plan on dropping the forks you need a centerstand (or rear wheel stand) and you need to jack up the front of the bike. Also make sure there is enough slack in the brake line going to the front to accommodate the drop of the front.
dwayneh likes this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #9 of 15 Old 06-05-2018, 12:46 PM
50mm, about 2 inch? one set of risers I have was only an inch straight up, the other was up and back about 1 1/2 that was done without disturbing the triple tree.
That really sounds like a lot more work than loosening the cables and trying to reroute. what about loosening the guide that the cables run through?
dwayneh likes this.
post #10 of 15 Old 06-05-2018, 12:49 PM Thread Starter
dwayneh's Avatar
I will attempt all non messing with triple tree options first. Im like you, prefer to not mess with the Triple trees.
Current ride:
Past rides:
dwayneh is offline
