Recommendations for Lowering Kit?? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 8Likes
post #1 of 18 Old 04-12-2018, 06:25 PM Thread Starter
Ron Strommer's Avatar
I need to lower his bike at least an inch, prefer 1.5". I see that there is a large, wide "dog bone" in between two semi-triangular plates. Which piece(s)needs to be replaced and who sells a good kit at a reasonable price?
Thx.
Ron
Ron Strommer is offline
post #2 of 18 Old 04-12-2018, 07:13 PM
Adventure Tech LLC. Rick is the man.
NVDucati and BrianS like this.
"I won't be wronged, I won't be insulted, and I won't be laid a hand on. I don't do these tings to other people and I require the same from them."
John Bernard Books The Shoootist
JWnWyoming is offline
post #3 of 18 Old 04-12-2018, 07:20 PM
nvr2old's Avatar
I'll second that.
Ron Strommer likes this.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #4 of 18 Old 04-12-2018, 07:30 PM Thread Starter
Thanks. I bought links from him on my previous 650 and they worked fine. His lowest is 1" and I wouldn't mind a little more than that but can't find much else out there.
Btw, I love your John Wayne quote. That's been my personal motto from the first time I saw The Shootist in 1979.
post #5 of 18 Old 04-13-2018, 12:41 AM
Never go more than an inch, install lower seat and wear higher heel boots as well. Are you looking to flat foot or balls of your feet?
BrianS likes this.
post #6 of 18 Old 04-13-2018, 03:02 AM
BKP
BKP's Avatar
Rick's dog bones, at Adventuretech, go up to 1-1/8". More than that, and you risk safety issues with your suspension (and fork, if you're raising the forks at the same time -- which I've always done to maintain the same bike geometry).
BrianS likes this.
[B][I]Barry[/I]
2017 Pearl White 650[/B]
AdventureTech lowering links and GPS mount
AdventureTech +2" SS braided brake line
Madstad windscreen
GPI spools, SW Motech risers
Givi XS307 Tanklock bag and Givi 46L top case
Suzuki hard case saddlebags
BKP is offline
post #7 of 18 Old 04-13-2018, 09:41 AM
I've never used them but I believe that links from Soupys Performance claim up to a 4" drop. As stated above though, there is a physical limit to dropping the rear as the links do not change the travel of the swing arm. At some point the wheel is going to get up-close and personal with the under side. And of course the geometry gets a little chopperesque.
Bentwee is offline
post #8 of 18 Old 04-13-2018, 09:53 AM
BrianS's Avatar
They can claim whatever they want but 4" drop can't be safe ...
Toronto, Canada
2015 V-Strom 1000
BrianS is offline
post #9 of 18 Old 04-13-2018, 11:06 AM
Agreed. I'm not recommending them. Just answering the OP's question. And giving the same warning as you. My hope is that Soupy would recommend having the shock altered to reduce travel if used for more than 1" or so drop.
BrianS likes this.
Bentwee is offline
post #10 of 18 Old 04-13-2018, 10:38 PM Thread Starter
Just my balls
And thanks guys. I ordered the 1" from Adventure tech. I also removed those thick rubber spacer things from under the seat. That was good for a half inch.
Ron
Big B likes this.
