Rostra: So Close... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 2 Post By bighammer
post #1 of 4 Old 04-06-2018, 05:03 PM Thread Starter
bighammer's Avatar
Rostra: So Close...
Diagnostic LED and brake light comes on and when CC power is turned on. Pull the brake lever and they go out. Other buttons will flash LED if brake is held, feel like I'm close, but brake relay wiring must be off just a bit.
pvwheeler and jinstall like this.
2018 Flee-Strom 1000XT
bighammer is offline
post #2 of 4 Old 04-09-2018, 03:53 PM
Motor7's Avatar
You have #85 to the wite w/black stripe brake wire found down under the coolant reservoir bracket?
#30 and 86 tied together to battery ground?
'15 DL650XT
Motor7 is offline
post #3 of 4 Old 04-09-2018, 04:07 PM
Motor7's Avatar
Sorry, that is with no control pod/handlebar switch....use the Rostra provided relay diagram for that:
'15 DL650XT
Motor7 is offline
post #4 of 4 Old 04-10-2018, 09:07 AM Thread Starter
bighammer's Avatar
There are so many diagrams out there, and some are wrong. I had printed a version of the 2nd one (without the 2nd relay) and soldered in a relay socket. I was pretty careful to write what went where, etc. and double checked, but it still was not working. I've cut out the socket and just have a relay with solder-less connectors (using a different diagram) and it's working now.
