Barkbusters install on 2018 XT...not a 'Turn Key Solution' - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #11 of 16 Old 12-20-2018, 05:18 PM
bighammer's Avatar
I had to replace my bars after a minor crash. The OEM hand guard was rashed on the left side, so I bought a pair of used BarkBusters from another member on here. My new Pro Taper bars are same profile, but actually aluminum, not steel like OEM.
The bar end internal clamps were too large, so I put them on my lathe and carefully shaved them down until they fit. The clamps on the tapered part were too small and had to be opened up a bit. A die grinder and files took care of those. I know parts for were available to remedy each problem, but I didn't want to spend more money and time in getting it roadworthy again.
2018 Flee-Strom 1000XT
bighammer is offline
post #12 of 16 Old 12-20-2018, 07:50 PM
America First's Avatar
First off, thanks for all the folks here posting helpful pictures and details. Barkbusters Storm hand guards (and Oxford Heaterz Premium Touring Heated Grips) will be installed on my 2017 DL650; does anyone know if the DL650 handlebars have the same install issue as the XT? Just want to be able to let the install person know of any possible hiccups with the Barkbusters install. FYI I am ordering the https://www.revzilla.com/motorcycle/...awasaki-suzuki from Revzilla.
Also, some posts in this thread discuss using the OEM bar ends (think that's what they are called) with the Barkbusters. I saw there are Barkbusters Accessory Ė Bar End Weight (EXTERNAL) which look great, though it seems to me they'd serve the same purpose as the OEM bar ends (reduce vibration). https://www.revzilla.com/motorcycle/...ar-end-weights
Thank you for your help!
2017 DL650 (white)
America First is offline
post #13 of 16 Old 12-24-2018, 01:04 AM
MeefZah's Avatar
Also, some posts in this thread discuss using the OEM bar ends (think that's what they are called) with the Barkbusters. I saw there are Barkbusters Accessory – Bar End Weight (EXTERNAL) which look great, though it seems to me they'd serve the same purpose as the OEM bar ends (reduce vibration). https://www.revzilla.com/motorcycle/...ar-end-weights
The DL650 bars are steel 7/8" and the product you linked SHOULD work for those bars. IIRC that is the model I bought for my old DL650. That kit will also include the Barkbuster bar end wights that go between the BB spine and the handlebars. The weights you linked are not needed.
America First likes this.
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You canít grasp its vastness from a plane. Itís diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
MeefZah is offline
post #14 of 16 Old 12-26-2018, 06:23 PM
Awesome, MeefZah- thanks for your help!
2017 DL650 (white)
post #15 of 16 Old 12-27-2018, 08:42 AM
Love that message to self!
Bob S.
2017 Vstrom 650 Base model (White)
2017 Yamaha YZ250X (Sold)....Hopefully WR250R soon
Previous loves:
1982 Yamaha 650 Seca
1978 Honda CB550
1975 Suzuki GT380
1977 Yamaha RD400
1973 Can Am MX1 125 (bought while Mom out of town)
Nicad is offline
post #16 of 16 Old 12-27-2018, 11:16 PM
MeefZah's Avatar
Yeah I get carried away with speed once in a while (GPS top speed on a DL1000 is 127mph, BTW), don't know that I pay any attention to the note anymore but it gets some laughs from people that see it.
MeefZah is offline
