Amber turn signal lenses - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 12 Old 12-02-2017, 01:03 PM Thread Starter
MetrickMetal's Avatar
Does anyone know of any replacement amber turn signal lenses for the DL1000's, and I like the look of ambers lenses over the clear ones.
2018 black DL1000XA with Arrow header, Holeshot slip-on, mag rims w/silver rim tape, Custom Lamm seat, Aprilia Tuono mirrors, V-Stream sport screen, Givi hugger, Cox radiator guard and lots of custom parts and mods
2007 Suzuki Candy Sonoma Red naked Bandit 1250S/AK7.
MetrickMetal is offline
post #2 of 12 Old 12-03-2017, 08:58 AM
Some of the Gixxes folks swap the amber for clear because they hate the amber. I'll try to remember to look this afternoon and see if they are interchangeable.
-Gary
2016 GSX-S1000FA
2012 DR650SE
2011 Burgman 400
2007 Honda Helix
2013 V-Strom 650 - sold
G-Dub is offline
post #3 of 12 Old 12-03-2017, 09:07 AM Thread Starter
Thanks, and let me know what you find out.
I found some on eBay from China for $9.09 a pair shipped.
https://www.ebay.com/itm/Turn-Signal...75.c100623.m-1
post #4 of 12 Old 12-03-2017, 09:09 AM
Fox
Fox's Avatar
I bought a set of whole signals from Aliexpress, but it looks like you can get just the lenses for $11.39. Only downside is 12-20 days lead time. Check out https://www.aliexpress.com/item/For-...593499562.html
Fox is offline
post #5 of 12 Old 12-03-2017, 09:44 AM Thread Starter
I've bought parts before from Aliexpress, but these lenses won't fit the 2014+ DL1000 turn signals
post #6 of 12 Old 12-03-2017, 12:48 PM
Fox
Fox's Avatar
Oh sorry, didn't realize they were different
Fox is offline
post #7 of 12 Old 12-03-2017, 02:05 PM Thread Starter
I removed the amber bulb from one of the turn signals and the pins are offset from the centerline of the bulb, and I have some clear single filament
12v/21w bulbs with centered pins and they won't fit.
I went to O'Reilly's auto parts and they didn't have any with offset pins, and the guy there said he's seen them but can't remember where. I did a Google search and found bulbs with offset pins but they were amber color, and I need clear bulbs for the amber lenses.
So does anyone know where to get a 12v/21w single filament clear turn signal bulb with offset pins?
post #8 of 12 Old 12-03-2017, 02:27 PM
nvr2old's Avatar
If I remember right the offset was done purposely to keep you from putting clear bulbs in. Filing a pin off on the clear bulb can make it work.
G-Dub likes this.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is online now
post #9 of 12 Old 12-03-2017, 03:06 PM
The lenses are basically interchangeable from the 2016 GSX-S1000F, and probably a bunch of other bikes. I don't know if you can see in the picture, but the clear lens has two little tabs on it and the amber has one. If you were putting clear in place of amber you would have to cut off the extra tab, but the amber should be a direct replacement for the clear. There are two types, mirror images of each other.
-Gary
2016 GSX-S1000FA
2012 DR650SE
2011 Burgman 400
2007 Honda Helix
G-Dub is offline
post #10 of 12 Old 12-03-2017, 03:57 PM Thread Starter
Thanks, and I ran across a post from a forum today that mentioned doing just that. So I just filed off one of the pins on a clear bulb I had and it locked up tight with just one pin, and I can't feel any difference in tightness between the stock dual pin bulb.
