Space Under the Seat - Page 4 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 14Likes
post #31 of 45 Old 06-18-2019, 10:46 AM
Webfors's Avatar
I suspect it is. There may be slight differences on routing the new fuel vent/overflow tube.
I was surprised how little room the '18 1000 has compared to my '15 650. I had all kinds of stuff under the 650 seat!
Two wheelz for realz!
'18 DL1000XT
Webfors is offline
post #32 of 45 Old 06-19-2019, 11:32 AM
MeefZah's Avatar
Originally Posted by Daniel Falin View Post
hello all,
sorry for bringing this old thread up, but since I found the info, I did not want to open new thread about it.
my question is, is this EVAP remove guide mentioned in this thread applicable for 650 v-stroms also ? 3rd gen 2017+
the charcoal canister looks exactly the same.
thanks in advance !
I can't imagine there's any difference.
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You canít grasp its vastness from a plane. Itís diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
MeefZah is offline
post #33 of 45 Old 07-12-2019, 02:53 PM
looks like easy operation removing this, I assume there is no need to mess around with that selenoid?
offnote is offline
post #34 of 45 Old 07-12-2019, 06:28 PM
MeefZah's Avatar
What solendoid?
MeefZah is offline
post #35 of 45 Old 07-12-2019, 06:46 PM
Originally Posted by MeefZah View Post
What solendoid?
vent valve.
offnote is offline
post #36 of 45 Old 07-13-2019, 12:55 PM
Thanks to the wonderful Meef, I regained my tool storage on my '18 California 1k. Thank you for the easy to follow tutorial!
MiteyF is offline
post #37 of 45 Old 07-13-2019, 06:26 PM
MeefZah's Avatar
Ha! You're welcome.
MeefZah is offline
post #38 of 45 Old 07-13-2019, 06:27 PM
MeefZah's Avatar
vent valve
Just leave it
MeefZah is offline
post #39 of 45 Old 09-23-2019, 09:42 PM
I am about to do it to mine 650 xt and as I look instruction on this thread I think there is no need to pop up tank and unhook the hose from it,
just reroute it down to the ground after unhooking from canister, right?
offnote is offline
post #40 of 45 Old 09-25-2019, 06:19 PM
MeefZah's Avatar
Well yes and no. There are two hose under the tank (IIRC) so get the correct one; and the hose won't be long enough to route to the bottom of the frame so you'll need to add length to it or replace it entirely with a longer hose.
MeefZah is offline
