Lowering the Seat Height - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 13Likes
post #1 of 18 Old 09-09-2017, 11:56 PM Thread Starter
Sentinel's Avatar
I'm considering a move up in CCs and touring capability from my Gladius to the new V-Strom 1000. My problem is that I have about a 29" inseam on a good day. I see that Suzuki offers a Low Seat for the Strom 1000, but I'm not sure how much lower it actually is. Sargent offers a Low Seat that's about 1" lower than stock, but I'm sure that only 1" lower won't be enough for me. I also see that lowering links are available, so I suppose if I got the Sargent Low Seat and some 7/8" Lower Links, that might be enough, but I surely can't go and drop the big bucks on a new bike without being absolutely certain on all of this.
Do you have any other suggestions or info that may help?
Sentinel is offline
post #2 of 18 Old 09-10-2017, 12:14 PM
BrianS's Avatar
Suzuki low seat is about 20mm (2cm) lower than stock. From what I've heard, the seat itself is a bit less padded (foam removed) therefore less comfortable. I bought AdventureTech lowering links (forum member) but I haven't installed it yet. After about 2 months of ownership I think I just got used to my bike's height. Unfortunately, it's impossible to determine if any of these remedies will be adequate, you gotta ride a bike to tell if it works for you or not.
Old Time Rider likes this.
Toronto, Canada
2015 V-Strom 1000
BrianS is offline
post #3 of 18 Old 10-03-2017, 07:48 PM
dwayneh's Avatar
I am only 5'7". I did test ride a BMW R1200GSA, and didn't have any issues, but I also weighed 100 lbs more back then....so....
dwayneh is offline
post #4 of 18 Old 10-03-2017, 07:49 PM
dwayneh's Avatar
I did read somewhere about removing rubber blocks from under the seat to lower it. May apply only to older Stroms..I don't know.
dwayneh is offline
post #5 of 18 Old 10-03-2017, 08:03 PM
Stromtrooper.com Sponsor
richlandrick's Avatar
You can use lowering linkage plates and raise the fork tubes in the triple clamps. Many Vee2 owners have done this. It is not hard or expensive.
Gen 2 DL1000 - AdventureTech, LLC.
Feel free to call me if you want to talk about it. See contact information on my website.
richlandrick is offline
post #6 of 18 Old 10-03-2017, 08:15 PM
29" inseam should be no issue, and you most certainly do not need to flat foot a motorcycle.
Old Time Rider, BrianS and dwayneh like this.
post #7 of 18 Old 10-03-2017, 08:33 PM
branthopolis's Avatar
Its (suzuki low seat) also narrower (thus more rounded) towards the tank. The "less comfortable" is subjective... I actually find my low seat more comfortable than the stock seat.
Rolex and dwayneh like this.
~Mark
2015 DL1000A
2005 YZ250
branthopolis is offline
post #8 of 18 Old 10-04-2017, 12:44 PM
dwayneh's Avatar
I am going to the dealership this evening to sign some paperwork, and actually throw a leg over the 1000. I have only ever sat on the 650, so before I take delivery I better see now if I need the lowered seat.
Big B likes this.
Current ride:
2018 V Strom 1000 XT
Past rides:
Honda NX 125 enduro, Yamaha V-Star 650, Suzuki 1500 Intruder,
BMW R1150R, BMW K1200S,
Triumph Sprint ST 1050 (Caspian Blue), Triumph Sprint ST 1050 (Silver)
dwayneh is offline
post #9 of 18 Old 10-04-2017, 02:34 PM
Confession time. I have a 30" inseam. One of my legs is slightly shorter than the other two, and I occasionally fall over when at a stop. It's very embarrassing.
post #10 of 18 Old 10-04-2017, 02:55 PM
Boots
I have the prob because I got a custom saddle, which is thicker. I got RR's lowering links and got back the in or so I'd lost. Others have also mentioned getting logger-type boots which have full last, metal plate, and Vibram sole, all which will add a good in of "leg length." I have the Forma Adventure boots, which also add at least an in in leg length and provide lots of protection. I think one forum member got a shoe repair shop to make up a High Sole boot for him by gluing material to the boot mid sole, it's kind of short platform shoe/boot and may be workable for you.
https://www.formabootsusa.com/collections/all
Wildbill1945 is offline
Tags
1000 , height , lower , seat
