TC ABS Engine light all came on today - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 09-02-2017, 06:02 AM Thread Starter
markymark11's Avatar
Went over a bump in the road and the TC ABS & Engine management lights all came on. The power cut as if it was running on 1 cylinder and I rolled it to a stop.
I lifted the seat and checked as much as I could get at, was all tight and connected and looked for any fluid leaks but all seemed fine so I re-started it and it fired up fine and feels like both cylinders are firing - but all 3 of the the lights stayed on along with FI flashing on the dash and the speedo doesn't work just reads 0mph . The rest of the dash seems fine - the oil light goes out and the gear position works.
It is booked into the dealer for first service on Monday and they will look into this as well.
Has anyone else had this problem with their 2017 ?
You can't teach a pig to sing...its a waste of time and it annoys the pig.
markymark11 is offline
post #2 of 8 Old 09-02-2017, 07:33 AM
Motor7's Avatar
Sounds like a bad ground, or a main connector that is loose or compromised. Whats the voltage at the battery while running?
'15 DL650XT
Motor7 is offline
post #3 of 8 Old 09-02-2017, 07:49 AM Thread Starter
Ignition on bottom display showing 12v before starting.
Start the engine and after a couple of seconds the display changes to 14.0 v ....14.2 v when I blip the throttle (same as it has been from new so far)
It has done 560 miles from new - never got wet or gone off road.
The bump I hit was a bad bit of road surface, enough to give a good jolt.
post #4 of 8 Old 09-02-2017, 07:54 AM Thread Starter
The dealer will look at it Monday but for my own peace of mind I would like to see if I can locate or solve the problem. It stops me always having the thought in the back of my mind. I can get a bit paranoid about reliabilty.
post #5 of 8 Old 09-02-2017, 10:51 AM
Check the wheel sensors that feed wheel speed info to the ABS and traction control modules. Is the speedo registering okay?
post #6 of 8 Old 09-02-2017, 01:29 PM Thread Starter
Front wheel sensor
It looks like it was the front wheel sensor. I got help from the UK forum and a couple of great guys suggested wheel sensors and sure enough the front one had jolted loose. I was really concerned and who would have thought that the dash would display "FI" and "engine management light" for a wheel sensor. The TC and ABS lights with 0mph makes sense but the others ?
Anyway - thank you for your input and a lesson learned for me that the lights don't always mean what they say
post #7 of 8 Old 09-02-2017, 01:30 PM Thread Starter
Thank you Greywolf
post #8 of 8 Old 09-09-2017, 08:30 PM
Bugzy's Avatar
How does that jolt loose? It is bolted in place. Was the bolt loose?
Bugzy is offline
