The windscreen and buffeting thread for the 2017+ DL1000, the only one! - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
post #11 of 39 Old 04-13-2017, 05:30 PM
WeeSwe's Avatar
I got a reply from Givi in Italy today and there will be a new AF for the 2017 DL1000.
- "The specific accessories range is in realizations. Monitoring our site in the next weeks for all infos"
2017 KTM 1090 Adventure
2012 DL650 black (sold)
2003 Yamaha TTR600 blue (sold)
WeeSwe is offline
post #12 of 39 Old 04-13-2017, 08:36 PM
RhinoVStrom's Avatar
The Air-Flow of the 2014> V-Strom 1000 will fit on the 2017 V-Strom 1000. But the Air-flow of the 2014>V-Strom 1000, won't fit on the 2017 V-Strom 650. The mounting is different. The mounting holes of the 650 are further apart. ( about 2,5cm)
There is no better ride than a V-Strom ride
RhinoVStrom is offline
post #13 of 39 Old 04-19-2017, 02:46 PM
Originally Posted by RhinoVStrom View Post
And the story is the same.
Is it the same even with DL1000? 2017 screen looks less curved and a little taller, it should provide less buffeting and more wind protection compared to stock 2014-2016 screen.
Originally Posted by realshelby View Post
Sounds like the 2014+ screen is different from the 2018 DL 1000 screen in part numbers at least. I wonder about whether the mounting pattern is the same?
Do you have part number for 2017+ stock screen? I was thinking to try it on my 2015 Vee, but local dealer still doesn't have any info on 2017/18 models.
DSot is offline
post #14 of 39 Old 06-27-2017, 10:35 AM
philthunder's Avatar
Puig 5852 visor
Some measurements of the 2017/18 Strom 1000 screen.
I have added the Puig 5852 250x100mm adjustable visor. This is a screw mounted additional visor, you can get it with clamps if you do not want to drill the screen. I'm 5' 10'' While buffeting with the new Suzuki screen is fine I found it somewhat noisy. With the Puig it is much better, acceptable in fact and at half the price of the MRA X-creen, worth trying. It does not have as much fine adjustment as the X-creen but I found on the X-creen the rounded lip caught the sun and was very distracting. Without the visor I had the Suzuki screen upright and on top position, with the Puig I have it right back and on top position (highest) it looks better for it. With the screen fully upright the bike looks like a startled Cockatoo
The visor comes with template to drill the holes and buttons to go over the screws.
What is this life if full of care we have no time to stand and stare
AT OUR BIKES.
philthunder is offline
post #15 of 39 Old 06-28-2017, 12:33 AM
Just picked my 2018 vstrom 1000 a few days ago. I find the buffeting ok but find it a little noisy. Does Suzuki make a taller screen to fit this bike. I had an MRA screen on my last bike (an AT) and that worked well. The adjustable lip made a big difference. My 09 vstrom 650 had a givi and that worked great but was so tall that I looked through the top of it.
wrider is offline
post #16 of 39 Old 07-12-2017, 11:43 PM
Bought a givi airflow windshield today. What a difference. No buffeting and quiet.
Lrobby99 and MariusD like this.
wrider is offline
post #17 of 39 Old 07-20-2017, 05:54 PM
Thumbs up Quiet rider
Sounding good so far then. How high are you setting the the Givi and how high on the 3 bike mountings have you got the screen. Some pictures would help.
AT OUR BIKES.
post #18 of 39 Old 07-20-2017, 10:09 PM
I am not at home right now but I have it mounted in the top holes and the front sliding windshield is approx 1 to 2 inches raised. I run it tipped up in the second notch. It worked fine in the first or lowest position but the added Adventuretech Gps mount makes contact with the dash. Once I find a piece a piece of rubber to put in between the gps mount and the dash, I will put it back in the lowest position. When I return home, I will post photos...if I remember.
wrider is offline
post #19 of 39 Old 09-23-2017, 11:40 AM
bosnjo's Avatar
I can confirm that there are no major changes in terms of buffeting between '14 and '18 models. I just sold my '14 and got '18. I had to install Givi Airflow and after today's ride I see I'll have to put BMW wind flaps I removed from my '14. Belly wind that was entering my helmet from bellow on '14 and that I have solved with wind flaps, is still there on '18, maybe a little bit less pronounced but still enough to hit my eyes. My helmet has chin curtain but it doesn't help.
2017 DL1000 White
2014 DL1000 Red (sold)
2012 DL650 White (sold)
bosnjo is offline
post #20 of 39 Old 09-23-2017, 07:47 PM
Originally Posted by WeeSwe View Post
Does anyone know if the Givi AF for DL650 2012 would fit DL1000 2017. Looking at givi.com they seem to be different articles, but who knows.
Just placed on order on a new yellow 2017 and if the AF is a must I might as well ask them to order it.
//Daniel
The Givi Airfow from the 2014-2016 will fit the 2017-2018. V-Strom.
Lrobby99 likes this.
