Slipper Clutch Adjustment? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 1 Post By realshelby
  • 2 Post By Johnny Rowland
post #1 of 8 Old 10-20-2019, 12:16 AM Thread Starter
Have a 2014 DL1000, bought in spring to replace a older DL650. Sweet bike!
I know the V2 has a slipper clutch, and wonder if it be adjusted; I think I might like it a bit more slippery.
Tx, Mike
meick is offline
post #2 of 8 Old 10-20-2019, 04:37 AM
No it can't be adjusted. Sure you know the function of so called slipper clutches?
Cheers Tom R
"No Fear" just means you are not going fast enouh yet. life begins when you get outside that comfort zone.
Current rides
18 Busa
14 Vee2
13 Husky TR 650 Terra
08 Busa(now sold)
07Vee1(now sold)
02 Busa (sold)
97 TLs
97 TRX
92 NSr
Current Projects
38 BSA Goldie
Upcoming projects,perhaps by the time I get retired just maybe
83 GSX11(gunna be bought forward now as I don't have a going across frame 4)
71 A100
tomrux is offline
post #3 of 8 Old 10-20-2019, 11:31 AM
Yes, they can be adjusted. But be sure that is what you want. You would have to be doing some rather aggressive downshifting into turns to really benefit from changes in the stock parameters.
Michael Schmidt has been installing the 2014+ style inner hub assembly into SV 1000's for a while now to replace their finicky BTL style "slipper" clutch. Requires some shimming to set them up to work If I remember correctly.
Big B likes this.
realshelby is online now
post #4 of 8 Old 10-21-2019, 11:18 PM Thread Starter
Yes I know what a slipper clutch is supposed to do, thanks.
If it is not easily adjustable then that's fine. When (If) I need to have the bike in a dealer shop I will have a chat with the mechanic anyway.
meick is offline
post #5 of 8 Old 10-22-2019, 10:34 AM
I doubt you will run into many shop mechanics that would even attempt to "adjust" a slipper clutch in these. Nothing in the manual about it.
Of course there is nothing in the manual about modifying clutch baskets either!
Michael Schmidt hangs out on the SVPortal and SVriders. I can get you in touch with him about ANY power modifications or transmission/clutch work. He runs my clutch baskets in his engine builds.
post #6 of 8 Old 10-26-2019, 03:10 AM
My V2 is the first bike I've had with slipper clutch and I can't tell if it's doing anything, I can still get the rear tire to step out a bit downshifting into second or first unless I'm spot on with rev matching, and even the I'll get a chirp in first when on the brakes. I was under the impression that it gets rid of that altogether, but may be it only minimizes it. It's fun, I've got no want to change things but I expected different.
blackrat is offline
post #7 of 8 Old 10-26-2019, 05:01 AM
Try using better tires ?.
That's a serious comment, I've never been able to chirp the rear on a downshift even on wet roads though admitted I'm not trying to either.
The original TL's would leave long black streaks on the road on downshifts so personally I'm happy with the DL's clutch
PeteW is online now
post #8 of 8 Old 10-28-2019, 10:26 PM
Johnny Rowland's Avatar
Just had my 2014 DL 1000 apart if you want to see it
Bugzy and Gert like this.
Johnny Rowland is offline
