Battery Removal - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By TXTrooper14!
post #1 of 6 Old 10-18-2019, 03:13 PM Thread Starter
TXTrooper14!'s Avatar
Battery Removal
Removing the battery to give it a charge on my larger charger. Owners manual doesn't make sense. Says to "Remove the screw. Pull off cover hook The cover has a hook at the circled place" I'm not finding the hook and the cover seems to form a plate where electrical connections, like the fuse box, are sitting. Hate to poke around and break something, especially electrical. Any helpful input appreciated.
Webfors likes this.
Mark
'14 V-Strom 1000 Adventure
'12 Aprilia Shiver 750
'92 BMW K75RT
Ride like the wind
Straining the limits
Of machine and man
Laughing out loud with fear and hope
I've got a desperate plan
-Rush
TXTrooper14! is offline
post #2 of 6 Old 10-18-2019, 03:35 PM
Webfors's Avatar
If you're facing the front of the bike, there's one screw on the left side. Then there are two hooks near the back of that plastic plate that need to be pushed backwards to the back of the bike to free them from the hooks. You will not release the whole thing from the bike, because of the aforementioned wires that connect to the top of that plastic plate. But you can easily move it out of the way to remove the battery.
So one screw near the left front, two nooks at the bottom back... just need to slide it backwards to release.
Two wheelz for realz!
'18 DL1000XT
Webfors is online now
post #3 of 6 Old 10-18-2019, 03:36 PM
Webfors's Avatar
That being said, if you want to charge your battery periodically with an external charger, simply install an SAE unswitched plug to your battery. You'll have a dongle under the seat that you can pull out and plug into your external charger.
That's what I do with my fancy external chargers. Saves time, effort and skinned knuckles.
'18 DL1000XT
post #4 of 6 Old 10-18-2019, 03:37 PM
Webfors's Avatar
Like this:
https://www.amazon.ca/OptiMATE-CABLE...76274293&psc=1
'18 DL1000XT
post #5 of 6 Old 10-18-2019, 04:48 PM
blaustrom's Avatar
See post # 22: https://www.stromtrooper.com/dl1000a...removal-3.html
Whilst you are in there install a charging pigtail for future use. Best is to get a "Battery Tender" or equivalent. I have my bike on it always when parked.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #6 of 6 Old 10-18-2019, 07:01 PM Thread Starter
Thanks for the great input guys, the text and photos make it much clearer Now that I see it, removing the V-Strom battery is easier than my K75.
My Vee came with a SAE pigtail and I've got it hooked up to a Battery Tender Jr. My Mac Tools charger only has the clips, but does a good job of giving a deep charge before winter sets in.
Mark
'92 BMW K75RT
Ride like the wind
Of machine and man
-Rush
