clutch lever mod - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 08-26-2019, 07:48 PM Thread Starter
clutch lever mod
hello guys,
i changed my levers for some fxcnc.. seems great.. but for the clutch side, i cannot put the setting to 1 or 2 because it does not engage the Clutch or sensor for the sensor because nothing happens when you want to start the bike... is there a way to adjust the clutch or sensor..
thanks
swiffer88 is offline
post #2 of 4 Old 08-26-2019, 10:30 PM
Spec's Avatar
Originally Posted by swiffer88 View Post
hello guys,
thanks
Position 1 is farthest from the bar I'm guessing?
If so you could build up the contact point on the lever that pushes on the master cylinder pin or extended the pin somehow.
Spec is offline
post #3 of 4 Old 08-27-2019, 07:27 AM
bosnjo's Avatar
I had that problem on mine but was easily solved by just unscrewing the clutch switch a bit and bringing it closer to the lever. But, only if you've got new levers for your model of the bike. I'm using the same levers on my '18 model that I removed from '14 model. On '14 model there was no need for any adjustment and on '18 model I had to do as described above.
2017 DL1000 White
2014 DL1000 Red (sold)
2012 DL650 White (sold)
bosnjo is offline
post #4 of 4 Old 08-27-2019, 08:07 AM Thread Starter
no 1 is the closest to the bar, for the lever..but the closest you place the setting the further the little cylinder in the lever, where sits the clutch ""pin"" is out
and yes it supposed to be a part for my bike... i already ask the company, waiting for a reply
