Non OEM centerstand - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 2 Post By Coach23101
post #1 of 3 Old 08-18-2019, 11:47 AM Thread Starter
offwegoagain's Avatar
Non OEM centerstand
Does anybody have any experience with the centerstand from the link below on V2?
www amazon com/MotoBrackets-269702-Centerstand-Suzuki-DL650/dp/B00BUIC176 (sorry or the brute link, I need to have 10 posts to add a link - silly rule for a year 2019)
I'd be especially curious to find out if it works with SW-Motech skid plate and Yoshi pipe - not necessary both at once.
It costs about 1/3 of the oem and I do not have budget for original at this point. On the other hand I'm not sure if i need it for anything other than my oil changes, everything else should be doable from the lift.
Custom signature...
offwegoagain is offline
post #2 of 3 Old 08-18-2019, 11:50 AM
outdoorgb's Avatar
That is the lest expensive one I have seen...in the market so would like some reviews also if anyone has tried this.
https://www.amazon.com/MotoBrackets-...gateway&sr=8-1
"This will be the last bike I'll need to buy"...
outdoorgb is offline
post #3 of 3 Old 08-18-2019, 12:23 PM
Coach23101's Avatar
Location: Seattle in the summer and East Cape, Baja in the winter. Perfect!
I have one and it works well except the right leg is slightly short and the bike leans a tiny bit.
Going to grind the paint off the bottom of the foot and JB Weld a thin shim on to see if that lasts.
The lean is so small it is a visual issue really.
Took about a year for the springs to loosen up to the point that I don't have to assist the bike in getting up. Now it is a foot only process.
I have a Weld 86 skid plate so don't know about others.
I have had it for over a year and am pleased so far.
notacop and offwegoagain like this.
Coach23101 is offline
