2014 - 1k onboard volt meter - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
post #1 of 15 Old 08-09-2019, 10:19 PM Thread Starter
V Trooper's Avatar
My onboard volt meter reads 13.8 - 13.9 when running at idle. My battery charger volt meter says 14.6. Are these stock volt meters that far off or are they reading from different points on the bike?
The bike when off and just key on also displays 11.8v on the dash meter and 12.6v on the battery charger volt meter. (Charger not plugged into wall, just reading volts)
Is this normal?
2014 VSTROM 1000 ADV.
V Trooper is offline
post #2 of 15 Old 08-10-2019, 03:49 AM
Gert's Avatar
It depends on the total voltage drop, based on the wire thickness plus distance of the volt meter from the battery. The shorter distance to the battery, the less the volt drop is, unless you increase the diameter of the voltmeter to battery wiring. Try it for yourself by connecting the onboard volt meter to the battery first and then record the reading. Now, install the volt meter in the intended position and take a second reading. The voltage difference may vary with around 0.1 - 0.5 Volt.
You could also have a high resistance at one of your connectors or the onboard meter just simply reads low. There could be a difference between the accuracy of the different meter used.
NVDucati likes this.
Gert is offline
post #3 of 15 Old 08-10-2019, 07:25 AM
Yeah, mine has a similar kind of drop. I've checked the on-board meter against my multi-meter a number of times and have simply gotten use to the difference. I run my dash mounted volt meter thru my aux fuse box, so I figured I'd experience some voltage drop -- but then I used some thicker wire to get the signal from there to the handlebars, hoping to not lose more. When riding down the road, I now know what to add to the reading to know where my battery and system really are. Early on, it bothered me that the reading on the dash was low. But after checking it multiple times to be sure the bike is not having an electrical issues, I now know what factor to just mathematically add to the reading to know the 'real' value.
Yarz1 is offline
post #4 of 15 Old 08-10-2019, 05:51 PM
Rolex's Avatar
Mine is off by 0.4v
I fitted a volt meter in place of the power socket, I used the sockets power to run the voltmeter and it is down by 0.2v
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #5 of 15 Old 08-31-2019, 10:14 PM
Idahokid's Avatar
My volt meter reads 14.1 most of the time.
Idahokid is offline
post #6 of 15 Old 08-31-2019, 10:50 PM
nvr2old's Avatar
Mine too......
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #7 of 15 Old 09-01-2019, 02:27 PM
Sounds normal.
Voltmeters don't necessarily need to be dead accurate.
There real mission in life is to alert you to a CHANGE in charging rate/voltage at idle and higher rpm. If yours normally reads 14.1 when cruising down the road, and one morning you notice 12.6 volts.....time to figure out what is wrong before you are stranded!
Big B and Gert like this.
realshelby is online now
post #8 of 15 Old 09-01-2019, 03:54 PM
Odd readings on a digital VM is interesting. On the Wee it read a bit low until I installed the EB wiring and then got LED bulbs for the headlight. It reads much better now up to a 14.6 max.
On my BMW G650GS the other 2 digital meters, same as on the Wee, read 888 or 000 or some real voltage. Might be the vibration from the windshield bracket mount. One reads normal indications most of the time and the other meter goes bonkers as soon as the revs increase and it vibrates more. May have to rubber mount the bracket that holds the meter?
post #9 of 15 Old 09-01-2019, 05:58 PM
I do think you are reading far to much into what is not very much. Anywhere 13.5 to over 14 is just fine. If it gets below 13 or over 15 you has problems, otherwise forget it and ride the bloody things.
As Realshelby says watch for significant change, otherwise all is good.
Cheers Tom R
"No Fear" just means you are not going fast enouh yet. life begins when you get outside that comfort zone.
Current rides
18 Busa
14 Vee2
13 Husky TR 650 Terra
08 Busa(now sold)
07Vee1(now sold)
02 Busa (sold)
97 TLs
97 TRX
92 NSr
Current Projects
38 BSA Goldie
Upcoming projects,perhaps by the time I get retired just maybe
83 GSX11(gunna be bought forward now as I don't have a going across frame 4)
71 A100
tomrux is offline
post #10 of 15 Old 09-02-2019, 06:01 PM
Ago
Ago's Avatar
I noticed a change after the recall (I did both ECM and wiring recalls at the same time). Before it used to read at around 14, after the recall I never see it go over 13.5.
Itís been like this for quite some time and it seems to be at this level consistently; no issue with the battery so far.
Ago is offline
