Brake and Clutch Fluid time... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 2 Post By PerazziMx14
post #1 of 9 Old 07-01-2019, 02:35 PM Thread Starter
Have used Motul 600 or 660 in the past on my bikes. Would either not be appropriate here for both brakes and clutch?
2014 DL1000
Givi Crash Bars,Windscreen, Tail Case
Suzuki Tall Seat
Carphunter is offline
post #2 of 9 Old 07-01-2019, 02:46 PM
Bazooka Joe's Avatar
These are both DOT 4 rated, so yes, either are appropriate. (read the owners manual and/or the top of the reservoirs for the required rating)
18 1000 XT yellow. Bunch of goodies installed.
2015 Yamaha WR250F- Street plated woods bike
Previous rides- about 25 different bikes, mostly dirtbikes.
Bazooka Joe is offline
post #3 of 9 Old 07-01-2019, 02:47 PM
Car, I use DOT4 fluid in 2 of my bikes for both brake and clutch hydraulic systems, and the 3rd with a cable-operated clutch I use DOT4 in its braking system as well. If your fluid meets the specs called for by the manufacturer, I see no problem. Isnt your spec engraved on the reservoir cover?
I use BelRay Super DOT4 brake fluid in my bikes.
MAZ4ME is offline
post #4 of 9 Old 07-01-2019, 02:51 PM Thread Starter
i guess I was less worried about meeting spec, as i know they are DOT 4.. .but rather any reason someone had to not use this stuff (or something else) for other reasons. Have seen some posts about water absorption rates, etc for more permanency fluids...
2014 DL1000
Suzuki Tall Seat
post #5 of 9 Old 07-15-2019, 02:19 PM Thread Starter
i don't have my manual here... anyone know what volume brakes will take for change, and what volume for clutch fluid? deciding how many 500ml bottles i need to order for this.
2014 DL1000
Suzuki Tall Seat
post #6 of 9 Old 07-15-2019, 02:58 PM
PerazziMx14's Avatar
Good old Prestone DOT4 for $3.87 per 12 ounce bottle is all you need. You can use DOT4 brake fluid that costs 10x as much but it'll do nothing differently, better or for longer.
1 - 12 ounce or 355ml bottle should be more than enough for 3 calipers and the clutch.
July 4th weekend I did the ABS servo brakes on my 2006 R1200GS that has 3 calipers and the servo/ABS unit on a little less than 355ml.
Yesterday I flushed and bled the brakes on my 2007 R1200GS and used about 200ml.
In both instances I really flushed the brakes even after the fluid was running clean I continued to flush just because I had more than enough fluid to spare.
2thDr and Big Boy like this.
PerazziMx14 is online now
post #7 of 9 Old 07-15-2019, 04:41 PM
I've changed the brake and clutch fluid twice on my 14 DL1000. A 12 oz. bottle finished the job both times with maybe 15-20% to spare. I wasn't trying to make it a one bottle job but one was all it took get the fluid clear. Unless you spill or need to remove air bubbles, 12 oz. will do front, rear and clutch. Speed bleeders make it very easy. I've also used the inexpensive Prestone DOT4 with no problems.
moglink is offline
post #8 of 9 Old 07-21-2019, 08:03 PM
So how are you cycling the ABS pump to completely flush and bleed the system? I was under the impression it took an electronic tool to cycle the pump...
Sent from my Moto Z (2) using Tapatalk
2015 DL1000 ADV
2thDr is offline
post #9 of 9 Old 07-21-2019, 10:22 PM
blaustrom's Avatar
Correct.
I did my normal fluid change until everything looked nice and bright. Then I went out onto a slippery grassy parking lot fringe area and exercised both front and rear ABS multiple times. Went back and bled both front and rear again. Hope that did the trick. By coincidence today I again just went to that very spot an exercised both ABS again to make sure that there is new fluid in the ABS module. Under my normal riding ABS rarely gets activated.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
