Proper turn Signal relay for LED? (2014-2016 DL1000) - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 1 Post By blaustrom
  • 1 Post By Brockie
post #1 of 9 Old 06-13-2019, 02:43 PM Thread Starter
V-Tom's Avatar
Hi there,
What is the proper digital turn-signal relay to order fro my 2015 DL1000 if I want to switch to LED signals? I see lots of relays online but not sure how many pins, etc.
Thanks,
..Tom
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is offline
post #2 of 9 Old 06-13-2019, 06:09 PM
This one was recommended a while back. No personal experience.
LED Flasher Relay 7 Pin For Suzuki GSXR SV DL Lamp Turn Signal Flash Controller https://www.amazon.com/dp/B003UN4FXW..._OSRaDbHQWAW03
2015 V-Strom 650XT ABS
1969 Triumph Bonneville
EddieFL is offline
post #3 of 9 Old 06-13-2019, 06:37 PM
blaustrom's Avatar
The multi pin relay is for the 1st gen VEE, not the V2.
The V2 uses a standard flasher relay:
https://www.stromtrooper.com/dl1000a...her-relay.html
Any "electronic" flasher should work.
V-Tom likes this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is online now
post #4 of 9 Old 06-13-2019, 06:49 PM
Brisky's Avatar
This worked for me and was recommended on the other thread. $9 on Amazon
iJDMTOY (1) 3-Pin CF-13 CF13 EP34 Electronic Flasher Relay Fix For LED Turn Signal Light Bulbs
I have the Suzuki OEM LED’s and my flasher went out after 2yrs.
Brisky is offline
post #5 of 9 Old 06-13-2019, 07:49 PM
Skom300's Avatar
Flasher Relay Justech 2-Pin DC 12V Motorbike Turn Signal LED Flasher Relay Fits Motors Turn Signal & Hazard Warning for Universial 12V Motorbike Motorcycle Car https://www.amazon.ca/dp/B07L5K97R8/..._5jTaDbK51SKDM
This is the one I just put in from amazon and works great.
Skom300 is offline
post #6 of 9 Old 06-13-2019, 08:52 PM Thread Starter
V-Tom's Avatar
Thanks guys!
Next question is: never mind I figured it out thanks!
..Tom
My Opinion:
My Stroms:
V-Tom is offline
post #7 of 9 Old 06-13-2019, 09:24 PM
Rolex's Avatar
I have fitted a 2 pin LED flasher but I have only changed my front units to LED and it works fine.
I did read another post where they had used the 2 pin flasher with full LED units and the light on the dash did not go completely out between flashes.
They also said the Suzuki LED flasher is a 3 pin with the third pin being wired to earth, this ensured the light on the dash completely extinguished between flashes.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #8 of 9 Old 06-14-2019, 12:07 AM
Brockie's Avatar
The tail/brake light bulbs for my 2010 Weestrom are stock auto 1157's. I cannot see any reason why your bulb should be different - easy enough to check by removing the seat anyway.
1157 LED's are readily available.
https://www.ebay.com/itm/Brake-Stop-...frcectupt=true
https://www.ebay.com/itm/12V-LED-Lig...db89a5756c33f9
You can even get them as strobe LED's
https://www.ebay.com/itm/Alla-Lighti...frcectupt=true
V-Tom likes this.
Brockie is offline
post #9 of 9 Old 06-14-2019, 12:26 AM
blaustrom's Avatar
Make sure you get orange bulbs for the indicators. The tail light and brake light assembly are LEDs already.
V-Tom likes this.
Blau2 2014 DL1000A
