Idle slows when clutch pulled in? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 18 Old 06-12-2019, 02:33 PM Thread Starter
V-Tom's Avatar
I have a 2015 DL1000 which currently has almost 175,000 km or a bit over 108,500 miles. I have had clutch dragging issues pretty much since I got it and this appears to finally have been fixed (thanks to @realshelby 's modified Clutch Basket https://www.werksparts.com/.)
I think because of my clutch dragging I never noticed this before: When I pull in the clutch the idle drops. This doesn't matter whether it's in gear or not. When I release it the idle speeds up. As far as I know my generation of DL1000 never had the throttle assist when letting the clutch out that later models had. I doesn't seem be that as it isn't trying to keep the revs up. Ie it just seems to open the throttle slightly and stay there.
It also doesn't appear to be the result of something dragging the idle down as it doesn't matter if I am in gear or not and it happens at exactly the same point of travel of the clutch lever; I suspect when the clutch switch is activated. It also reacts a second or so after pulling in the clutch. If I am at a traffic light in neutral with the clutch lever released and pull in the clutch a moment later the idle has dropped from about 1,4000 to closer to 1,100. If I then put it in first the clunk is a bit less than if I did it quickly.
(I rarely go to neutral at lights but have been experimenting with how little my clutch drags now and how easy it is going into neutral and back into gear.)
Have you noticed this before?
..Tom
2015 DL1000 New July 2015 175,000+ km, 108,500+ miles.
SMIDSY detailed report.
V-Tom is offline
post #2 of 18 Old 06-12-2019, 04:45 PM
vTwinDino's Avatar
My 2015 definitely does bump the idle as the clutch is let out. If I pull the clutch lever to the bar and the clutch switch is triggered it will idle as if in neutral, but if I two finger the lever and it rests on my ring and pinky fingers then the revs stay higher
Sent from my Pixel 2 XL using Tapatalk
V-Tom likes this.
vTwinDino is offline
post #3 of 18 Old 06-12-2019, 08:04 PM
Rolex's Avatar
I had the EUC upgrade done to my 2014 and it now bumps up the idle but only when it is in gear, if the bike is in neutral it stays low.
I preferred the old ECU for that reason, I don't need or want a higher idle.
V-Tom likes this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #4 of 18 Old 06-12-2019, 08:04 PM
branthopolis's Avatar
My 2015 V2 does the same... If I pull in the clutch all the way the idle drops to its recommended level... As I release the clutch lever slowly or if I don't fully pull it in when coming to a stop, it idles maybe 100 rpm faster. It's done this since day 1 with both the original ecu and the recall ecu.
V-Tom likes this.
~Mark
2015 DL1000A
2005 YZ250
branthopolis is offline
post #5 of 18 Old 06-12-2019, 11:41 PM
blaustrom's Avatar
Confirm: I had the EUC upgrade done to my 2014 and after that it bumps up the idle when you let out the clutch lever. I think it's controlled by the clutch safety switch contact.
V-Tom likes this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #6 of 18 Old 06-12-2019, 11:56 PM Thread Starter
V-Tom's Avatar
By playing with the lever a bit you can find the exact point where it changes the revs. Interesting that there is a delay in dropping the revs and knowing there is that little bit of delay can help reduced the clunking when you go from neutral to first.
..Tom
V-Tom is offline
post #7 of 18 Old 06-13-2019, 06:24 AM
Griff2's Avatar
On my 2016 the opposite happens as far as I can see, but it has had the ECU replaced.
Griff2 is offline
post #8 of 18 Old 06-13-2019, 08:43 AM
NVDucati's Avatar
Low RPM Assist
I think this is a feature.
"Low RPM Assist
By adopting the new Low RPM assist system, the concern of an unexpected engine stall has been relieved. This system will automatically raise the idle speed when releasing the clutch or when riding at low rpms, assisting frequent clutch work in congested city rides and preventing sudden and unexpected engine stalling when riding in the low rpm range."
It first appeared on the 2015 SV so very likely on the V-Strom 650 as well. I don't remember it being in the Wee brochure until 2016, but I wasn't looking.
Member: AMA
NVDucati is offline
post #9 of 18 Old 06-13-2019, 09:14 AM
"Low RPM Assist
Yes, it is a feature of the newer DL 650. But these are 2014+ DL 1000's they are wondering about in this thread. I don't think I have seen Suzuki literature claiming the new 1000 has this feature?
realshelby is offline
post #10 of 18 Old 06-13-2019, 09:27 AM
erci's Avatar
Mine's a 2014 1000 and it had all of the TSBs addressed by dealer. It does the same thing.. idle drops as the clutch switch is activated. Meaning it bumps up the idle to prevent stalling as you ease out the clutch. Not a necessary feature, but also not all that intrusive.
erci is offline
