Bike keeps cutting out then won’t start - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #1 of 23 Old 05-26-2019, 11:19 AM Thread Starter
Mikebike69's Avatar
1st time it happened 2weeks ago was out for an hour in light rain made 2 stops then set off bike cut out without warning then wouldn’t start had to call recovery, 2nd time out in dry weather similar thing rode for half an hour made a couple of stops, would not start at all after stopping close to home so pushed it back, 3rd time yesterday started up on driveway ticked over fine, set off and cut out 50yards down the road, dash says check with an elevated temp reading any help appreciated
Mikebike69 is offline
post #2 of 23 Old 05-26-2019, 02:04 PM
Rolex's Avatar
The check & elevated temp reading is only there to get your attention.
Putting the bike in dealer mode would be a good place to start and check your battery cables are good and tight while you have the seat off, they have a tendency to work loose on bikes.
When the bike won't start what actually happens, will it crank & not fire or is there no crank ?
Will the fuel pump prime or not. ?
Does this happen with the bike in neutral or only when in gear. ?
What is displayed in the gear position indicator when this happens. ?
Have you made any changes to the bike. ?
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #3 of 23 Old 05-27-2019, 03:50 AM
Gert's Avatar
It sounds like with the CHEC on the display, either the side stand switch being activated or the emergency cutout switch is inter earthing / activating. The bike will not start with the CHEC displayed.
Gert is online now
post #4 of 23 Old 05-27-2019, 06:00 AM Thread Starter
Mikebike69's Avatar
Bike does crank but won’t fire, it shows bike in neutral but when check display on dash shows no gear selection or neutral, only mod done since I bought bike 2 years ago was putting a scorpion slip on can, not sure about oil pump priming, it does initial checks on turning key fired up from cold
post #5 of 23 Old 05-27-2019, 11:51 AM
If there is a problem with the kill switch, the side stand switch, the ignition fuse or their associated wiring, a CHEC will be displayed and all the temperature bars will fill to call attention to the display. If you see a CHEC rather than a heat icon (image of a thermometer in water), the bike is not overheating.
Hatchi is offline
post #6 of 23 Old 05-27-2019, 09:15 PM
Rolex's Avatar
If the kill switch or kick stand switch are activated or your ignition fuse is blown you will get the check and the temperature bars but the bike will not crank.
I would still like to know what symbol is showing where the gear position indicator is when this is happening.
You need to listen to the fuel tank when you turn the ignition on, each time you should hear the fuel pump run.
With a disconnected fuel pump, the bike will crank but not fire as expected but you do not get a check up on the dash.
With a blown fuel pump fuse the dash is blank and the motor will not crank.
2014 V2, Snoopy
Rolex is offline
post #7 of 23 Old 05-27-2019, 09:54 PM
That's true if it's in gear, but the motor will crank in neutral with the side stand down, so the side stand switch could be the issue.
Hatchi is offline
post #8 of 23 Old 05-28-2019, 01:20 AM
Rolex's Avatar
If the stand switch is bad the bike will start when in neutral but stall every time a gear is selected.
The stand switch only plays a part if the bike thinks it's in gear that is why I asked what is displayed in the gear position.
2014 V2, Snoopy
Rolex is offline
post #9 of 23 Old 05-28-2019, 05:21 AM
bosnjo's Avatar
I don't know what year is your bike. I've had '14 DL1000 and there was a recall for 3 wiring harness weak spots. One of them is "earth" cable that would loose tight contact with engine casing. If I can remember well it affected production year 2014 and 2015 (don't know about 2016). I did the recall on mine without having the problem. Other guys did have the problem just like yours.
2017 DL1000 White
2014 DL1000 Red (sold)
2012 DL650 White (sold)
bosnjo is offline
post #10 of 23 Old 05-28-2019, 06:53 AM Thread Starter
Mikebike69's Avatar
It’s a 2015 it not on recall for the three wiring problems but is on recall for a new ecu which I didn’t know about until I took it to the dealer about those three wiring issues I read about, hoping this is what’s causing the problem but won’t know until it’s changed
Bike wouldn't start? dakor82 DL1000A - 2014-2016 16 05-23-2019 07:02 PM
07 DL1000 won’t start after running fine all day Jason Dion DL1000 from 2002-2012 22 09-02-2018 07:38 PM
Help - farkling, and bike won't start! Frank29 DL650A - 2012-2016 15 05-25-2017 01:12 PM
OK Please help im in a tough spot. Bike wont start. Redline Maintenance, Tech and Products. 2 09-01-2015 10:06 PM
Looking at a V. 84Sabre General V-Strom Discussion 14 06-08-2014 02:54 AM
