Bike wouldn't start? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 17 Old 05-21-2019, 10:42 PM Thread Starter
So went down to my bike, tried to start it wouldn't even start to crank. Battery fine, Killswitch on bike in neutral.. after 15 seconds of mental f bombs, I popped it onto centerstand going to investigate, put up kickstand and it started fine. Put it back on kickstand not centerstand still fired up fine. Any guesses as to what happened? I didn't do anything and bike wasn't in gear when kickstand was down.
dakor82 is offline
post #2 of 17 Old 05-21-2019, 11:01 PM
jgendr's Avatar
Most likely the Neutral safety switch wasn't fully engaged. moving the bike around from stand to stand caused it to pop into engagement. I keep forgetting to neutral the bike before putting the stand down, you guessed it insta kill...
2014 DL650 VStorm
jgendr is offline
post #3 of 17 Old 05-22-2019, 02:36 AM
Rolex's Avatar
If it happens again have a look at the gear position indicator on the dash it should have a "N" if you have a "-" the bike thinks it's in gear.
Other than that the clutch switch is a likely cause.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is online now
post #4 of 17 Old 05-22-2019, 02:49 AM Thread Starter
Neutral light was on. So wasn't in gear according to computer, just weird... Last time I rode it I did get cought in a torrential downpour to the point where I had to get in rightlane, ride at 30, put hazards on, and open visor to attempt to see...but I doubt that had any issues.
dakor82 is offline
post #5 of 17 Old 05-22-2019, 09:05 AM
Maybe the starter button issue. Do you have headlight relays?
Hatchi is offline
post #6 of 17 Old 05-22-2019, 10:30 AM
dravnx's Avatar
The headlight relay has nothing to do with the starter switch start contacts.
L2 DL650 Adventure
bike X miles=smiles
smiles bike=miles
miles smiles=bike.
It's simple math.
dravnx is online now
post #7 of 17 Old 05-22-2019, 11:01 AM
Adding a headlight relay reduces the amount of current that flows thru the weak starter switch on start up.
Hatchi is offline
post #8 of 17 Old 05-22-2019, 12:06 PM Thread Starter
Headlight is stock.
dakor82 is offline
post #9 of 17 Old 05-22-2019, 12:21 PM
dravnx's Avatar
No, the headlight relay routes the high current headlight supply through the relay instead of the start switch. The start contacts within the switch and the start circuit remain unchanged. There are 4 contacts within the switch, 2 normally closed contacts for the headlight and 2 normally open contacts for the start relay. The headlight side of the switch is a normally closed set of contacts that open and remove power to the headlights when the start button is engaged. The headlight contacts will become oxidized, the resistance will increase and burn up the contacts. You can either install a relay to prevent this or you can disassemble the switch once in a while and clean the contacts. I make cleaning the switch part of the valve clearance check. 105,000 miles now and the contacts look like new every time I open the switch.
L2 DL650 Adventure
bike X miles=smiles
smiles bike=miles
miles smiles=bike.
It's simple math.
post #10 of 17 Old 05-22-2019, 04:55 PM
Rolex's Avatar
The V2 only has one headlight so they don't seem to suffer form the loads on the start switch.
The neutral light and the gear position indicator could be reading differently that is why I suggested looking at the position indicator.
The priming of the fuel pump is the most important part.
If you don't get the prime it is most likely one of the safety switches like kill switch or the kick stand switch (only if the bike thinks it's in gear)
If you get the prime the clutch switch could be a suspect, it's a easy test so a good place to start.
2014 V2, Snoopy
Rolex is online now
45 Countries on my Euro Trip. Bike for sale lancesulli Euro Troopers! 1 09-28-2016 09:52 PM
07 dl1000 Bike won't start, all gauges dead. TimStrom64 DL1000 from 2002-2012 2 05-03-2016 02:08 PM
Frosty Balls Ride, FL to PA Matt_Mc Ride Reports (Route Sheets) 15 01-27-2016 06:49 PM
