Rox risers ABS cable too tight - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
post #1 of 23 Old 05-09-2019, 02:35 PM Thread Starter
Hi,
I'm attempting to install some rox risers. The Abs line is way too tight. I don't really want to re-route it. Have snipped the zip ties. Was considering moving the ABS master cylinder forward to accommodate. Anyone have experience with this?
Thank you,
MM
medbowman is offline
post #2 of 23 Old 05-09-2019, 03:00 PM
PerazziMx14's Avatar
Are you referring to the brake hose? If so others have rerouted and were happy with the lie of the hose. I tried rerouting several different ways and was never satisfied with the results. So for me it was either get a custom length hose made (not expensive) or get rid of the risers. I ended up just going back to stock and selling the risers.
PerazziMx14 is online now
post #3 of 23 Old 05-09-2019, 03:02 PM
I was looking into putting 2" bar risers on my L2 Wee Strom. I noticed the manufacturer wrote somewhere that there is not enough play in the cables to install it without new cables.
medbowman likes this.
Danousd is offline
post #4 of 23 Old 05-09-2019, 03:49 PM Thread Starter
Thanks! I decided to go with the stock set up....too much hassle to re-route the ABS Brake line.
post #5 of 23 Old 05-14-2019, 12:54 PM
Having recently played around with risers on my 2016 DL1000, I can confirm that the front brake line is the limiting factor. No re-routing of the line can help as the short distance between the master cylinder and the manifold block on the front frame is the problem. No cutting of cable ties, nor re-routing of the line under the top triple clamp, will help (that actually hurts the situation due to the angled nipple on the manifold block).
I tried a 30 mm straight, non angled riser, and after removing all cable restraints from the triple clamp, both throttle/brake and clutch side, it kind-of worked. Turning the forks full lock on the clutch side was OK, but full lock on the brake side was definitely stressing the front brake line. Too much for me to be ever comfortable leaving it like that, even though the forks are really never turned into the lock towards the brake side.
I read information that 25 mm risers will work on 2014+ without issue other than maybe removing the retainer for the clutch line under the triple clamp. I'm not saying I doubt that, but after the 30 mm experience and knowing what that looked like, I KNEW I would be fine with 20 mm risers.
So, I bought 20mm SW-Motech straight risers. They fit perfectly, although I did still remove the clutch line retaining hardware from under the triple clamp. The brake side was left completely alone. There's no discomforting level of stress on any cable / hose line with the 20 mm's. Would 25 mm be alright? Maybe, but 20 mm, I can speak to with absolute certainty.
For me, the small bump in height really does improve my upright riding posture, but I wasn't needing anything gigantic as far as rise anyway (I'm 6'4" on a stock seat).
Nihilate is offline
post #6 of 23 Old 05-14-2019, 06:18 PM
Cmstbcchamp07's Avatar
I installed roxx 2in risers on my 18 1000 XT. I had to drop the forks and route the cables behind the top triple tree and it worked just fine.
Cmstbcchamp07 is offline
post #7 of 23 Old 05-14-2019, 06:44 PM
Highwayman2016's Avatar
I put 2 Rox and Adventure high bars on my 2014 650. Got the Galfer 2 longer brake hose. It was a pain to get to the fitting above the rad. All hoses and cables now run behind the fork.
Mulewright likes this.
2014 650 Strom
Highwayman2016 is offline
post #8 of 23 Old 05-14-2019, 11:01 PM
I just installed 2 Rox Risers on my 2018 1000XT and had to route throttle cables behind forks and and cut some zip ties to maximize cable routing, did not lower forks but did slide the front brake lever assembly inward on the handle bar a 1/2 and it all worked out well. This install does take some trial and errror but is worth it to me. Very happy with the risers.
Dhudgeon is offline
post #9 of 23 Old 05-17-2019, 09:59 AM
Bugzy's Avatar
I have 3.5" Rox on my bars. I replaced the upper part of brake hose with a SS braided line that was about 3 or 4 inches longer. Cost maybe $40 and all stock fittings used, nothing custom. I also replaced my clutch hose with a SS line, that cost another $40.
The electrical I had to route to other side of triple tree as I did not want to lengthen anything there, and it works fine like this.
It is easy enough to do this if you really want it.
NVDucati likes this.
Bugzy is offline
post #10 of 23 Old 07-12-2019, 09:10 PM
Hey all.......
I'm attempting to install a 2" ROX anti vibe riser on my 2014 V...I can confirm with a raised blood pressure, that the ABS hard line connections are a complete pain in the ass. I bought a longer stainless braided line with banjo fitting for the top, thinking the 10mm threaded end would marry to the ABS hard line flared fitting. No go... I've ordered more fittings, hoping that Russell part number 641471 or 641411 Adapter Fittings - Brake and Clutch Hose - Russell Performance Products will work... Does anyone know what the thread size or spec is for the ABS hard line fitting? I'm not sure how you guys are making the factory brake line work with a 2" riser. There is absolutely no way that it will work on my 2014, even if I commit to riding only in straight lines for the rest of my life...
tripleS is offline
Helmet locks - How do you secure your helmet when not riding bajabob General V-Strom Discussion 85 08-04-2016 02:20 PM
How tight is too tight (risers ) coneye DL650A - 2012-2016 23 09-11-2014 10:00 PM
Cable routing and risers? YellowHat General V-Strom Discussion 4 08-19-2010 09:45 AM
Rox Risers - Tight Wiring at Steering Lock ken mier DL650 and DL650A - 2004 to 2011 3 09-12-2008 07:39 PM
Enough Cable for 1"Up 1"Back Bar Risers? Shapeshifter General V-Strom Discussion 6 06-03-2008 10:48 PM
