Plug and Play H7 LED Bulb - Page 3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 62Likes
post #21 of 101 Old 05-16-2019, 06:59 AM
DaveinNC's Avatar
Check out Cyclops LED, they have a new H4 bulb out that is top tech and performance. I installed a set of their H4 4800lm bulbs in my Glee and they were awesome. Put a small hole in the center of the rubber dust cap, unscrew the bulb housings and sandwich the rubber boot between the bulb and fan, reinstall. The fan stays outside the boot and if you are careful you have a good tight seal. Im getting ready to install a set of their new H7 4800lm bulbs in my VFRX. Cyclops tells me the plastic caps screw right back over the fan, we will see.
"Dave"
DaveinNC is offline
post #22 of 101 Old 05-20-2019, 03:41 AM
bosnjo's Avatar
My first one was Cyclops. Very expensive and lasted for 3 months only, then one side blew. On ZDatt LED bulbs now. More then a year and H7 and H9 shine like a new.
Ah, and ZDatt is quarter a price compared with Cyclops.
2017 DL1000 White
2014 DL1000 Red (sold)
2012 DL650 White (sold)
bosnjo is offline
post #23 of 101 Old 05-20-2019, 07:04 AM
DaveinNC's Avatar
I never heard of them but I will check. I am also looking at the GTR perfect fit led. It is only like 20 watts so I'm not sure how that would fly.
"Dave"
DaveinNC is offline
post #24 of 101 Old 09-19-2019, 11:30 AM Thread Starter
V-Tom's Avatar
I installed the H7 LED "Bulb" last spring on May 4th, 2019 Yesterday I noticed my beam was all messed up with very little light going forward. When I got home I took a good look and the LED part separated from the mounting part. The LED is working and perhaps can be re-attached. It came as a two-pack so just took a few minutes to install the other one.
It was late last night when i got home from work (10ish) so I didn't have much time to see if it is designed to come apart like that and can simply be clicked back together. I bought it on Amazon so have emailed the vendor to see how they will take care of this.
Here is what it looked like:
31,300 km or about 31,322 miles. Don't know if this is a fluke or a testament to how cheap some things are made but it didn't last much longer than the Halogen H7's although at least it failed "soft" with some light being available so at least I wasn't left in the dark.
..Tom
Webfors likes this.
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is online now
post #25 of 101 Old 09-19-2019, 12:59 PM
Webfors's Avatar
A little epoxy will fix that right up. Amazon vendors are typically pretty good too. Wouldn't surprise me if they send you a new pair.
V-Tom likes this.
Two wheelz for realz!
'18 DL1000XT
Webfors is offline
post #26 of 101 Old 09-19-2019, 05:36 PM
Skom300's Avatar
I am running leds from a company called led eagle. They are a Canadian company. You can purchase directly from them or off of amazon. They use fans and fit well in a 2015 1000. And they come in a set of 2. Used them in both car and bike and would recommend them.
LEDEAGLE H7 LED Headlight Bulbs Light Kit 20x Longer Lifespan Bright Cool White 6000K-6500K 10000LM, Pack of 2 Bulbs https://www.amazon.ca/dp/B0799GFYNH/..._zA-GDbHW2TQHS
Skom300 is online now
post #27 of 101 Old 09-19-2019, 10:06 PM Thread Starter
V-Tom's Avatar
Do they fit inside the Strom Headlight system without any modification?
..Tom
My Opinion:
My Stroms:
V-Tom is online now
post #28 of 101 Old 09-19-2019, 10:49 PM
Skom300's Avatar
..Tom
Yes they do. The H7 has the adaptor that comes off to fit and then put the bulb in. And I also bought the H11 bulb for high beam. With them coming in pairs I have spares. They are a real quality build and very professional packaging. I think for $50 apiece they were well worth it.
post #29 of 101 Old 09-19-2019, 11:32 PM
i have some H9s that are a direct fit with no fan and the control is even built into heat sump so no dangling bits
I am planning to drop by V-toms work to confer
Motocanada is offline
post #30 of 101 Old 09-20-2019, 12:24 AM Thread Starter
V-Tom's Avatar
I'm trying to picture how that works with the plug being inside the cover. Is there actually enough room inside the cover for all that?
How many KM's do you have on the h7's?
..Tom
Webfors likes this.
My Opinion:
My Stroms:
V-Tom is online now
Plug and Play H4 LED headlight kicktheball Maintenance, Tech and Products. 8 06-02-2017 10:54 AM
Plug and Play Running Light Adapters - Info Needed richlandrick AdventureTech LLC 35 10-14-2016 01:50 PM
plug & play LEDs?-IntertiaLED CAN Bus LED Lights robfilms General V-Strom Discussion 4 12-25-2015 10:03 PM
Plug and play power for smartphone? everready Techy World! GPS, Electronics, etc 13 08-17-2015 11:36 AM
