Clutch or slave cylinder??? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
  • 2 Post By blaustrom
  • 1 Post By larolco
  • 1 Post By V-Tom
post #1 of 10 Old 05-01-2019, 03:55 PM Thread Starter
soberjoe's Avatar
Hey gang - here are the details and symptoms:
2014 DL1000
90,000 kilometres
If the bike is NOT running, in gear, clutch lever fully depressed: bike will not roll
If the bike is NOT running and I start it in first gear with the clutch lever fully depressed: bike lurches forward 2"-3"
If the bike is RUNNING and I drop it into first gear with the clutch lever fully depressed: there is a noticeable cla-clunk sound and the bike tries to move forward for a split second
A new clutch kit is relatively inexpensive from Suzuki, and I am not afraid to tackle the job, but I am looking for some input first - I have had my slave cylinder replaced once already due to a leak. Is it at all feasible that the symptoms indicated above are slave cylinder related?
Any input is appreciated - thanks all,
Joe
Joe
Today is the only day that truly matters. Here's hoping that yours is beautiful.
2001 Honda 750 ACE - written off May 25, 2014
2014 V-Strom 1000 - Purchased August 25, 2014 - first ride September 2, 2014
http://advjoe.ca/
soberjoe is offline
post #2 of 10 Old 05-01-2019, 04:04 PM
blaustrom's Avatar
Have you changed and bled the clutch hydraulic system recently? If not, that's the first thing I would try before tearing into the bike.
soberjoe and NVDucati like this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #3 of 10 Old 05-01-2019, 04:47 PM
larolco's Avatar
The clutches are stout in this motor. (My plates are still within spec at over double your mileage.) And when they start to go, you will have the opposite symptoms to what you are experiencing - slipping, not grabbing.
In all likelihood, your hydraulic system is acting up. This is exactly what happens when your fluid level is low. I'm on slave cylinder number 4 now. Each was rebuilt at least once as well.
Brockie likes this.
DRZ400SK17
larolco is offline
post #4 of 10 Old 05-01-2019, 05:15 PM
V-Tom's Avatar
Almost guaranteed to be the Slave Cylinder. I have been through several, one just last week. I have ordered a spare (again) but also am going to try rebuild the one that failed as it's pretty new.
..Tom
Big B likes this.
SMIDSY detailed report.
V-Tom is online now
post #5 of 10 Old 05-01-2019, 05:19 PM
V-Tom's Avatar
What kind of mileage is on your DL1000? trying to get a sense of how long the slaves have lasted (I am hard on things!)
..Tom
V-Tom is online now
post #6 of 10 Old 05-01-2019, 06:45 PM
..Tom
You just need to better clean all that lube/gunk back there regularly my friend.
post #7 of 10 Old 05-01-2019, 06:48 PM
V-Tom's Avatar
Could be but I ride in a lot of crap and I suspect taking apart the front sprocket area is part of the problem as well.v last time I changed it the area wasn't all the bad.
Seems like I am not the only one:
..Tom
V-Tom is online now
post #8 of 10 Old 05-02-2019, 08:41 AM
I really think there needs to be some work put into finding a better seal. Unless these are simply full of crud ( which shouldn't be getting past the seal...) then the material must be failing in the seal. Maybe something with a different lip design? I don't have one here to measure and research. But I would be if I was still riding a 1000.
realshelby is offline
post #9 of 10 Old 05-02-2019, 12:01 PM
larolco's Avatar
..Tom
199000kms as of today.
I think people who don't experience the slave failures aren't riding in slop. It's the wet weather that does them in. All chain fling that settles in the front sprocket area is directed precisely at the slave every time you park on the side stand. Put the side stand on the other side of the bike and I bet the slaves never fail.
DRZ400SK17
larolco is offline
post #10 of 10 Old 05-02-2019, 12:11 PM
V-Tom's Avatar
What you are saying dovetails with my riding. Lots of wet and crap. I'm only at 166,000 km so a bit short of you but it sounds like our slave cylinder lifetime is in the same ballpark.
..Tom
V-Tom is online now
Clutch Catastrophe, can't get slave cylinder back on The Revelator Maintenance How-to 1 06-18-2013 12:15 AM
DL1000 clutch won't release Stobie V-Strom Service and Maintenance Questions and Discussions 14 12-28-2012 04:01 AM
Clutch slave cylinder R&R Scott E. Bonds V-Strom Service and Maintenance Questions and Discussions 8 02-02-2012 12:38 PM
Leaking slave cylinder? pryde V-Strom Service and Maintenance Questions and Discussions 3 09-20-2009 08:42 PM
Replaced Slave Cylinder... No I Have No Clutch!!! WARainman Maintenance, Tech and Products. 12 05-26-2009 03:50 PM
