Wind Deflector search - Page 3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 11Likes
post #21 of 31 Old 05-01-2019, 01:09 AM
Wind deflectors
I used the general dimensions of the pattern posted earlier and cut the shapes out of a 200mm (8") black plastic plant pot. Only cost about $1.50 at our local hardware & sausage retailer. Cut them with bolt holes DOWN towards bottom of the pot / smaller diameter. Bolted on as usual with convex side out but they do need slightly longer bolts. They look like bought ones, match the black plastic parts on my 2012 650 beautifully. They do a great job of stopping wind funnelling up my chest & significantly reduce noise in the helmet. If you don't like the results / looks then buy another plant pot and start again. They only take about 10 minutes to make and can be cut with scissors.
As noted in an earlier post a big tank bag also stops a lot of this nuisance draft but I don't always want to carry that.
Chipwidget is offline
post #22 of 31 Old 05-05-2019, 12:55 AM
Done and problem gone.
CAP10 and ERockJL like this.
fayeslane is online now
post #23 of 31 Old 05-09-2019, 07:34 AM
JustAnotherDude's Avatar
Which deflector is that? They don't look homemade and if they are, damn they look good! I especially like they don't stick way out from the bike like some of the others.
JustAnotherDude is offline
post #24 of 31 Old 05-09-2019, 07:50 AM
Mucksavage's Avatar
@Chipwidget ....some pictures please?
'12 Glee, Metallic Fox Orange, '98 DR350
Mucksavage is offline
post #25 of 31 Old 05-09-2019, 10:43 PM
Can't post a link but search ebay for - Smoke Wind Deflectors Windshield for BMW R1200 GS Adventure LC 2013-2017
CAP10 likes this.
post #26 of 31 Old 05-15-2019, 03:47 AM
CAP10's Avatar
Amazing fit! Can you explain how you fastened them down? I see the regular fairing screw toward the rear but what is being done in the front? Thank you for this post! I believe it is actually what I want on mine.
CAP10 is offline
post #27 of 31 Old 05-15-2019, 06:10 AM
If you zoom in you will see a bit of dual lock as mentioned in previous posts. Reversible mod with no damage to original fittings.
post #28 of 31 Old 05-15-2019, 01:29 PM
These are installed in reverse of how they would be on a R1200GS, correct? What did you use to plug the original mounting holes? Solid grommets?
2014 DL1000
post #29 of 31 Old 05-15-2019, 04:58 PM
Yep, solid grommets.
post #30 of 31 Old 05-15-2019, 10:54 PM
NVDucati's Avatar
Originally Posted by fayeslane View Post
A big tank bag cuts the air flow a fair bit. Mine is a Touratech.
I agree (tank bag). That huge hole that the front forks need to turn is what the winglets are trying to defeat. They create a low pressure behind themselves that in turn draws some of the air coming up through the hole off to the sides.
A few years ago I posted this in the massive buffeting thread. I'm not necessarily suggesting it for everyone but the part about the yarn can help test your progress.
https://www.stromtrooper.com/dl1000a...ml#post4286369
fayeslane likes this.
Member: AMA
NVDucati is offline
Windscreen and Buffeting Thread for the 2012-2016 DL650... The only one!!! 1 deadeye DL650A - 2012-2016 2194 05-14-2019 09:04 PM
How do I keep the wind out of my coat tail? Dave F General V-Strom Discussion 15 10-31-2015 05:50 PM
Wind Layer under mesh suit in hot weather? K9 Wee General V-Strom Discussion 15 07-09-2015 07:36 AM
Wind is relentless in central west NSW Solo Traveller 1964 Australia-New Zealand 10 03-04-2013 05:51 AM
