Hard wiring Tom Tom Rider 400 2014 DL1000 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 7Likes
post #1 of 17 Old 04-20-2019, 12:08 PM Thread Starter
Hey folks!
I am sure this has been discussed in depth, however, I have been searching the forums and cannot seem to find anything definitive. I would like to hard wire the Tom Tom Rider handlebar mount directly to my 2014 1000. I want to leave my 12v free for charging other devices. Can anyone give me some advice for this and/or provide a link to a previous discussion on this topic?
I am pretty sure the rear light is the way to go in terms of attaching and I have heard Eastern Beaver has a plug and play option. Any advice and help would be appreciated!
Dwrock27 is offline
post #2 of 17 Old 04-20-2019, 12:52 PM
I highly recommend the Eastern Beaver PC-8 fuse block, especially if you want something close to "plug and play". I am not the most mechanically, or electrically, inclined but I installed one on my 2011 650 as well as on my 2018 1000 with no problems. On both I connected circuits for battery tender, heated gear, and hard wired GPS. The fuse block makes it super easy to add electrical accessories and have them connected to switched or constant power while keeping everything tidy. The hardest part ends up being routing wires which is really not difficult, just takes a bit of time to get it the way you want them.
Edit: If you search the forum you'll find a bunch of posts about both hard wiring GPS as well as fuse block installs / info. I suggest using Google to search the forum - e.g. "site:stromtrooper.com PC-8 GPS"
V-Tom, 2thDr, Dwrock27 and 1 others like this.
-Cambion
2018 V-Strom 1000XT
2011 V-Strom 650A (Sold)
"Remember, you don't really own anything you can't carry at a dead run."
Cambion is offline
post #3 of 17 Old 04-20-2019, 12:58 PM
V-Tom's Avatar
Defiantly eastern Beaver for plug and play relay kit and their PC8 fusebox (which gives you both switched and unswitched power.)
Everyone's different but I prefer my GPS to not be on switched power. I don't know abut the Tom Tom but my Zumo's are very little power draw the odd time I forget to shut off and nice to have powered when I stop if I want to search things or build routes while stopped.
..Tom
2thDr and JustAnotherDude like this.
2015 DL1000 New July 2015 165,000+ km, 103,000+ miles.
SMIDSY detailed report.
V-Tom is offline
post #4 of 17 Old 04-22-2019, 07:13 PM
Another vote for products from Eastern Beaver. I have a 3 Circuit Solution on my ST1300 (all unswitched), and I just ordered another 3 circuit solution for my Vstrom (also, all unswitched). Great, simple and effective products.
As far as switched vs unswitched, that's up to you. I take the GPS off every time so I'm not worried about it being powered all the time, plus I want external powerlets or other cables to be on all the time for charging/multimeter checks. And I like to (sometimes) run a wire under the topbox to charge electronic devices while riding, or while at a rest stop.
Alexi
sfalexi is offline
post #5 of 17 Old 04-23-2019, 07:19 AM
+1 on the EB fuse block. Get it. You'll be glad you did
Houstrom46* is offline
post #6 of 17 Old 04-23-2019, 11:42 AM
Rolex's Avatar
I have the Zumo and it is wired directly to my battery, I hated the thing wanting to shut down every time I turned the ignition off.
If you want it on switched power you can just use a piggyback spade fitting and get your power from the horn, a quick & easy solution.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #7 of 17 Old 04-23-2019, 12:00 PM Thread Starter
Thanks for the info!
I am completely clueless when it comes to electronics! If i only plan on wiring the GPS and POSSIBLY another 12v down the road, would the 3 circuit solution suffice or do I definitely need the PC8? Right now I don't plan on getting additional lighting or heated gear.
Dwrock27 is offline
post #8 of 17 Old 04-23-2019, 12:18 PM
RCinNC's Avatar
An Eastern Beaver PC-8 is probably your best bet, unless you're going to go whole hog and buy one of those computerized power distribution blocks that don't use fuses and instead use electronic circuit breakers. Those are smaller than the PC-8, but way more expensive.
This is the page for the relevant parts for your bike: https://easternbeaver.com/Main/Bike_...om/vstrom.html
The PC-8 allows you to have different power options. You can make everything switched by running through a relay, or everything "always hot" by skipping the relay and running directly from the battery, or even a combination of the two; the PC-8 has the option of having two circuits always hot and the rest switched. The PC-8 gives you some flexibility, too; you might later decide to add other accessories like heated grips or additional power outlets, and the PC-8 has room for this expansion.
The nice thing about the PC-8 is that Eastern Beaver makes it plug and play. You don't need to splice wires or attach quick connects, and the instructions are pretty clear. I'm not an electronics guy at all, and I installed both the PC-8 and their headlight relay with no issues.
There are other power distribution blocks besides the PC-8; Blue Sea makes a nice one, as does CenTech. But for total ease of installation, I don't think you can go wrong with Eastern Beaver.
The simplest way is to wire the GPS mount directly to your battery with an in-line fuse, and that's fine if that's the only accessory you'll ever install. Installing a fuse block is kind of planning for the future. Keep in mind that there can be a parasitic drain from accessories attached directly to a battery, though, so if your bike sits for long periods of time with something like that hard wired to the battery, there's the potential for your battery draining.
RCinNC is offline
post #9 of 17 Old 04-23-2019, 12:23 PM
RCinNC's Avatar
You don't definitely need the PC-8. The three circuit solution would work, and if you later wanted to add a PC-8, you will have already installed the wiring and relay that you'd need for the PC-8. I like the PC-8 for the convenience; it makes for a very neat and orderly installation. This is what mine looked like under the seat on my old 2012 DL650:
RCinNC is offline
post #10 of 17 Old 04-23-2019, 08:56 PM
Rolex's Avatar
My Zumo has a 0.02amp parasitic drain.
That is when directly hooked to the battery and no unit in the cradle it pulls a constant 0.02amps
2014 V2, Snoopy
Rolex is offline
Tags
gps hardwire , gps mount , tom tom rider 400 , vstrom 1000
The 2014 DL1000 Acceleration is Quick SECoda DL1000A - 2014-2016 16 01-25-2017 08:57 PM
SV Racing Parts, 2014 Up DL1000 Elka Rear Shock Ready to Ship Now SV Racing Parts SV Racing Parts 4 12-14-2016 12:07 PM
New rider wanting first bike, possibly dl1000 hrdkorsocerplyr General V-Strom Discussion 92 08-04-2008 10:38 PM
