Front tire wears out before rear - Page 4 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
post #31 of 33 Old 04-15-2019, 02:06 AM
Originally Posted by Null 13 View Post
That's so dangerous Worst case scenario i'll use the rear brake to modify my trajectory, but using the front brake when you're engaged in a turn is a huge no-no.
It's not as dangerous as it seems, I'm braking late and hard and deep into the corner with very little or no lean, off the brakes, tip the bike, turn, start adding throttle progressively once the exit can be seen. Not the lines a sports bike rider would choose but it's a very fast way around a set of corners on a DL.
The only dangerous bit is that I'm closer to the outside edge of the road than is typical before I initiate the turn. On the other hand a DL with semi-knobbly tires doesn't automatically crash if the seal runs out and I've reduced the chances of becoming a hood ornament for oncoming traffic considerably.
IMHO skimming the apex of the corner which is the traditional 'fastest way round' is far more dangerous.
PeteW is offline
post #32 of 33 Old 04-18-2019, 12:37 AM
Null 13's Avatar
This explains a lot.
I'm more of a paced ride type of guy.
________
2014 VStrom 1000 Adv SE, because army bikes are more adv
Null 13 is offline
post #33 of 33 Old 04-19-2019, 01:15 AM
Just replaced the original BW Front after 15K miles. Tread was smooth on the left which matches my normal trail braking left turn into work. Rear still looks good.
Stromtacular is offline
Prep rear wheel for shop changing rear tire? jwtacoma DL1000 from 2002-2012 12 04-05-2018 10:25 AM
Shinko 712 rear tire long term review Copernicus Suspension and Tire Tech 8 07-13-2017 01:13 AM
Rear brake wobble after rear tire removal tsg Maintenance, Tech and Products. 15 06-10-2017 01:29 PM
Front Tire Profile Trekman DL650A - 2012-2016 4 08-23-2014 07:24 AM
My tire tale - new Pirelli Scorpion rear MrNobody Suspension and Tire Tech 7 07-22-2013 03:56 PM
