Front tire wears out before rear - Page 3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
post #21 of 32 Old 04-12-2019, 11:37 PM
Bugzy's Avatar
Could the front wheel be hitting the fender when it warms up from expansion? Seems far fetched, but I can't imagine a reason the front would wear out faster than the rear.
Bugzy is offline
post #22 of 32 Old 04-13-2019, 01:16 AM
joethebike's Avatar
My front PR4 lasted 18,470 km (11,476 miles) before replacement with a Metzeler Roadtec 01 and it still had some life left.
2005 DL 650 - 113,900km
1972 Suzuki T350 - about 105,000 miles (including 2 Castrol 6 Hour Races)
1982 Honda CX500EC - 259,000km
All owned from new
joethebike is offline
post #23 of 32 Old 04-13-2019, 04:51 AM Thread Starter
K so I'm in the minority, but others have had front go first....it's just never happened to me before. But also my first set of new rubber on the Strom... I feel like tires on my old versys lasted forever, granted I primarily used that bike as a NYC commuter and the would usually die to a screw, industrial staple, or road hazard before I ever got to wear them down.
dakor82 is offline
post #24 of 32 Old 04-13-2019, 05:09 AM
That's fairly typical for me on a DL650. It does handle well but I needed my weight well forward and I was sometimes sliding the front into corners under braking.
If you ride aggressively there isn't necessarily something wrong.
PeteW is offline
post #25 of 32 Old 04-13-2019, 10:00 AM
Null 13's Avatar
Just making sure, do you brake in corners?
________
2014 VStrom 1000 Adv SE, because army bikes are more adv
Null 13 is offline
post #26 of 32 Old 04-13-2019, 10:11 AM
locoblanco's Avatar
... sliding the front into corners under braking...
A bit of trail braking isn't a bad thing, and not scary at all with ABS.
I wore out the stock front Trail Wing in 6100 miles, while the rear went 8500. The replacement Metzler Tourance Next is at 7400 and looking good. Could be due to having a two ply tread and not so blocky tread pattern.
locoblanco is online now
post #27 of 32 Old 04-14-2019, 05:53 AM
Yeah.
Not all the way through the corner, but deep into the corner yes. Far deeper than a sportsbike rider will.
PeteW is offline
post #28 of 32 Old 04-14-2019, 10:36 AM
Null 13's Avatar
Yeah.
That's so dangerous Worst case scenario i'll use the rear brake to modify my trajectory, but using the front brake when you're engaged in a turn is a huge no-no.
________
Null 13 is offline
post #29 of 32 Old 04-14-2019, 10:53 AM
SECoda's Avatar
Fronts seem to wear out first on many Michelin's. They are the only tires I have used that do this. The front Anakee III on my V2 is wearing faster than the rear although they are still high mileage tires. The front treads are a bit shallow new IMO. I am generally a minimal brake user and tend to get on the higher end of mileage on tires normally. I still really like them.
SECoda is offline
post #30 of 32 Old 04-14-2019, 07:50 PM Thread Starter
Anakees 3 are prob my next tire...
dakor82 is offline
Prep rear wheel for shop changing rear tire? jwtacoma DL1000 from 2002-2012 12 04-05-2018 10:25 AM
Shinko 712 rear tire long term review Copernicus Suspension and Tire Tech 8 07-13-2017 01:13 AM
Rear brake wobble after rear tire removal tsg Maintenance, Tech and Products. 15 06-10-2017 01:29 PM
Front Tire Profile Trekman DL650A - 2012-2016 4 08-23-2014 07:24 AM
My tire tale - new Pirelli Scorpion rear MrNobody Suspension and Tire Tech 7 07-22-2013 03:56 PM
