Fog light wiring - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #11 of 11 Old 04-16-2019, 10:01 PM
Bugzy's Avatar
Likely grounding it to the frame is what caused all your issues. maybe if you just move the ground to the battery it will work, but you need to move the positive lead to a switched line someplace so you don't forget to turn it off one day and kill your battery, and a fuse block is the easiest approach to that. The fuse block also has a relay on it.
Bugzy is offline
K7 tail light wiring question DesertBike DL1000 from 2002-2012 1 12-22-2016 09:20 AM
Quick help: Wiring for brake light XTwarrior1985 DL650A - 2012-2016 2 06-22-2013 08:37 AM
Wiring the Bestem 929 with LEDS to EB: walk-through MrNobody Maintenance, Tech and Products. 9 04-22-2013 10:41 AM
'09 Brake Light Wiring elees DL650 and DL650A - 2004 to 2011 1 03-28-2009 11:17 PM
