2014 Starts and runs but dies - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 11Likes
post #1 of 23 Old 04-07-2019, 07:38 PM Thread Starter
Fired up the Strom this morning. I was bringing her from behind the house to the front to get ready to ride and after about 25 yards the bike shut down. I cranked her up and while it took a little longer for her to fire, she fired back up and ran about another 25 yards and the same thing happened. The bike will start after cranking (cranking for a little longer than usual) then shut down after about 20 seconds of run time. The bike has good gas, and it will die at idle, or while on the throttle.
Any ideas?
Bville-Bud is offline
post #2 of 23 Old 04-07-2019, 07:43 PM
Any diagnostic trouble codes? Miles on the bike? Last time ridden before the problem occurred? Any recent work done on the bike? Not enough info here to assist.
MAZ4ME is offline
post #3 of 23 Old 04-07-2019, 07:48 PM Thread Starter
Ooops I think I'm in the wrong forum since a 2014.
No trouble lights, it has 20,000 miles on her, ran great less than a week ago when I put the kickstand down. I did take the battery a couple fays ago out to check it before I went out with my girl today, and it checked fine.
post #4 of 23 Old 04-07-2019, 09:29 PM
Sounds potentially like some bad gas to me.......but the last thing you messed with was the battery.
V-Tom and eff like this.
post #5 of 23 Old 04-07-2019, 09:42 PM
blaustrom's Avatar
Did you have rain, Bike exposed to the weather, Possibly water got into the tank?
Like Big B is saying, make sure the battery contacts are tight.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #6 of 23 Old 04-08-2019, 11:30 AM
Bugzy's Avatar
This could be a dead battery. Check the voltage while it is running to see if it drops below 12v.
Bugzy is offline
post #7 of 23 Old 04-08-2019, 06:20 PM Thread Starter
Thanks for the input. Battery is good. Fuel is good.
post #8 of 23 Old 04-08-2019, 06:46 PM
And you know the fuel and battery is good how? If you have done nothing to your bike since the last time you rode it and was fine, then IMHO the only 2 things to focus on first are the battery and fuel. Batteries do weird things my man, I know this from personal experience.
2thDr likes this.
post #9 of 23 Old 04-08-2019, 08:14 PM Thread Starter
Took the battery to the battery shop and it checked out. She was VERY low on fuel when stalling, and I filled it with a gas can & new gas. Maybe I could drain and check, but I think I'm OK. Thoughts?
BTW - thanks for your patience & thoughts
Hatchi likes this.
post #10 of 23 Old 04-08-2019, 10:45 PM
NVDucati's Avatar
Spark _ Fuel _ and .... AIR
Any chance a critter has made a nest in the air intake?
Gas cap air vent clear?
Charcoal canister?
The other thing you haven't said yet: during the 20 seconds of life will it rev up freely?
Will it start without pulling in the clutch lever?
Member: AMA
NVDucati is offline
Starts, runs, headlights on - but no instruments or turn signals DesertBike DL1000 from 2002-2012 11 03-11-2019 03:00 PM
2003 DL1000 dies once EVERY DAY rsamsel DL1000 from 2002-2012 12 06-18-2018 01:41 PM
Starts & runs fine when cold, engine starts to misfire when warm mushu DL1000 from 2002-2012 10 06-18-2018 10:42 AM
Dies at idle Wee Willy Winky DL650 and DL650A - 2004 to 2011 9 11-04-2014 10:25 PM
CHEC indication, but it starts and runs okay maz_norcal DL1000 from 2002-2012 2 08-24-2014 09:41 PM
