Idle thoughts - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 03-30-2019, 06:08 AM Thread Starter
Idle thoughts
14-16 guys - do our models no longer have the handy undertank idle adjustment screw I've seen described as existing on earlier models? I'm hoping not so, as would like to up mine by a little but don't know how. If no handy screw, how is it done??
GerardDeR is offline
post #2 of 7 Old 03-30-2019, 02:37 PM
Bugzy's Avatar
This is handled by the ECM now, there is no adjustment for it. With the updated ECM (part of recall) it will have a faster idle when first started and then settle down to around 1200/1100 RPM after.
Bugzy is offline
post #3 of 7 Old 03-30-2019, 06:17 PM Thread Starter
Mine does not do this - idle isn't faster on startup. When was this recall? I'm Australia. How might one check if recall change was made do you think?
post #4 of 7 Old 03-30-2019, 06:40 PM
branthopolis's Avatar
Contact a Suzuki dealer and provide them the VIN number.. They should be able to see if the recall has been done.. They may need to look at the revision number printed on the ECU itself to see if it needs replacement.
~Mark
2015 DL1000A
2005 YZ250
branthopolis is offline
post #5 of 7 Old 03-30-2019, 07:01 PM
stu53's Avatar
As far as I know there wasn't a full recall on the ECU in Australia. It is on a case by case basis as apparently not all ECUs here are affected.
It is a good ideas to contact a Suzuki dealer workshop and see what they have to say about your issue.
There have been several recalls do do with electrical wiring on our bikes, so you should also check with the workshop to see if they have been done on yours.
This is the thread where an number of us Aussies related our ECU experiences.
https://www.stromtrooper.com/austral...v2-ecu-oz.html
DL1000A 2014
previously DL650K6
stu53 is offline
post #6 of 7 Old 03-30-2019, 08:10 PM
Rolex's Avatar
The one thing I hate about my new ECU is the high idle.
Check out the Aussie part of this forum it will tell you how to go about getting the upgrade.
I told my local shop if they got me a new ECU I would pay them to service my bike at the same time as they fitted the ECU, they ordered the ECU there and then while we were talking.
Remember to take both keys with you for the upgrade as here down under we have a chip in the key, not all bikes get that.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #7 of 7 Old 04-05-2019, 07:08 PM
V2man's Avatar
Here is another link in regards to the ECU swap in Oz.
https://www.stromtrooper.com/austral...ement-ecu.html
2014 DL1000A 2014 -
2012 DL650L2 2013 - 2014
2007 DL1000 "Bowser" 2009 - 2013
V2man is offline
Idle adjustment with PC3 gopi.sandy V-Strom Service and Maintenance Questions and Discussions 4 08-04-2018 07:40 AM
Cold start - no high idle problem ahtoxa11 DL650A - 2012-2016 2 05-06-2017 09:03 PM
Fuel Pump Not Fully Priming - Bike Cuts Off - Erratic Idle Jforte1 DL1000 from 2002-2012 5 03-27-2016 07:09 PM
Power Commander zero map noticeably changes idle Hammerdown77 DL1000 from 2002-2012 3 12-05-2015 10:20 AM
v-strom 650 engine idle RPM, fuel eco. and stalling problems Gaszton DL650 and DL650A - 2004 to 2011 4 10-31-2015 03:14 PM
