Brake Light stopped working - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 8Likes
post #1 of 30 Old 03-25-2019, 04:48 PM Thread Starter
Looking for some help as I've been unable to figure out why my brake light stopped working.
The running light bulb works but when I squeeze either the front brake lever or the rear brake pedal, the bulb doesn't brighten.
I'm having a hard time believing both the front and rear switches went at the same time. I've checking the wiring under the seat at the tail and there doesn't seem to be any issues.
I'm thinking maybe a relay issue but I don't know enough. Any help would be greatly appreciated. Thanks
baggio95 is offline
post #2 of 30 Old 03-25-2019, 05:32 PM
Just asking...but did you look at the bulb(s)? What year WEE?
MAZ4ME is offline
post #3 of 30 Old 03-25-2019, 05:32 PM
Tail light filament is not integral with the brake light filament. The brake light filament can be defective/burnt out and the tail light will still be lit. Pull the bulb and check.
richlandrick likes this.
badjuju is offline
post #4 of 30 Old 03-25-2019, 05:34 PM
I suggest that you take the bulb out and verify that the brake function filament is intact. Applying +12V to both contact points, with the return connected to the flange, should illuminate both the brake and running light. If they both work, plug it back in. You may find that this has cured the problem. (I cured the same problem with mine that way once.) I think that the contact point material is a non-noble metal which oxidizes over time with temperature cycling and vibration, finally becoming too resistive to allow enough current to pass. Removing and reinstalling the bulb breaks through the oxide. You could even scrape the contacts clean before putting the bulb back in.
chicago likes this.
Trepidator is offline
post #5 of 30 Old 03-25-2019, 06:10 PM Thread Starter
Thanks guys. I'll pull the bulb and check.
The bike is a 2014 DL1000
baggio95 is offline
post #6 of 30 Old 03-25-2019, 06:17 PM
bosnjo's Avatar
is 2014 fitted with bulb or LED? I could swear it was LED but now I'm in doubt.
2017 DL1000 White
2014 DL1000 Red (sold)
2012 DL650 White (sold)
bosnjo is offline
post #7 of 30 Old 03-25-2019, 06:21 PM Thread Starter
Bosnjo,
You are correct, it's LEDs. Any other ideas?
baggio95 is offline
post #8 of 30 Old 03-25-2019, 06:27 PM
I would pull apart the connections, clean with electric contact cleaner and retest your brake light. If that works and you found no corrosion, apply dielectric grease around the connector but not on the contacts to keep water out going forward.
Sent from my Moto Z (2) using Tapatalk
2015 DL1000 ADV
2thDr is offline
post #9 of 30 Old 03-25-2019, 06:27 PM
Baggio, I'm in my '14 DL1000 wiring schematic.
You have 3 wires going to that LED bulb. One is a Black/White wire which is a common ground running to battery (-). Another is Brown from the ignition switch, and the 3rd is a White/Black wire running to both front and rear brake switches. A White/Green from the #2 Signal fuse powers both front and rear brake switches.
You have a ground in the B/W wire, otherwise the running lamp portion of the bulb wouldnt be operating. The running lamp portion of the bulb is working which means the Ignition Switch Brown wire is powered. Which leaves the White/Black wire from both brake switches, the White/Green wire running from the #2 Signal fuse, or the #2 Signal fuse itself as possible culprits IF you dont have power at the 3-wire bulb socket with either brake switches activated--OR the bulb connection or bulb itself itself as the possible culprits. In the socket you have 2 powers, one from the ignition switch key ON, and one from either brake switches, and a ground. If you have the powers and grounds youre supposed to have, it HAS to be bullb-related.
MAZ4ME is offline
post #10 of 30 Old 03-25-2019, 06:30 PM
Rolex's Avatar
You rear brake switch will need adjusting 100%
Your brake light will be working but it will permanently on.
You need to put some slack in the spring between the brake pedal and the light switch.
richlandrick and blaustrom like this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
2012+ 650 rear brake pad replacement JorgeLuis DL650A - 2012-2016 20 11-28-2018 12:47 PM
Tail light, brake and rear turn signal wiring Stoopy DL1000A - 2014-2016 35 09-11-2015 11:30 PM
Intermittent brake light - problem at the front brake connector maz_norcal General V-Strom Discussion 1 07-09-2015 10:35 AM
12 O'clock Labs Programmable Brake Light Flasher Module SV Racing Parts SV Racing Parts 1 03-03-2015 12:16 PM
