Limp Mode: Secondary Throttle Valve Actuator c28 & c65 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 10Likes
post #1 of 18 Old 03-16-2019, 09:05 PM Thread Starter
NVDucati's Avatar
Went on this year's first local Wednesday ride and at about 40 miles in my bike went into "limp mode" and the FI light came on. As you may know, that is when it will run fine if you only tenderly open the throttle. Puled over shut it off poked, cursed, got back on. No light and it would accelerate as normal for about 2 miles. Then the light and limp.
Made it home okay (Limping still allows you about 70mph if you nurse it.) The next day was the same 2 mile limit before the light comes on. In dealer mode it shows two codes; c28 & c65. Engine temp normal. Voltage normal.
I've read through the forum and don't see a lot about it. I did find one thread where GreyWolf asked the victim if his bike would start without pulling the clutch lever in. (huh?) He answered yes, replaced the clutch-lever switch and the problem went away. Man GreyWolf was good. I never doubted him before and I have always robotically pulled the clutch to start. So I tried it and my bike would start without pulling the clutch. So that will likely fix the c65 code. But I can not believe that will cure the c28 which seems to be that the secondary butterflies are not opening.
AS for recent maintenance: I did, a few days before, replace both sprockets and chain. Cleaned the clutch push rod. Installed a new rear tire. I had put maybe 20 miles on the bike after that and before the failure.
On the internet, at large, I have found tons of older GSXR guys having the sensor fail from failed soldering. When I look at the parts fiche the V2 part
.SENSOR ASSY #13580-27G21 $89 looks different in design.
Any help?
Member: AMA
NVDucati is offline
post #2 of 18 Old 03-16-2019, 10:23 PM
Just so we all know, what year, mileage, ECU swapped? How's your battery?
Sent from my Moto Z (2) using Tapatalk
NVDucati likes this.
2015 DL1000 ADV
2thDr is offline
post #3 of 18 Old 03-17-2019, 02:01 AM
Grimmer's Avatar
The position feedback for the secondary throttle valves passes through the connector on the top. I would check for an abraded short. I think this is the connector that was rubbing on the bottom of the tank that there has been so much discussion about. I'd have to check my bike to confirm.
Grimmer is offline
post #4 of 18 Old 03-17-2019, 02:41 AM
Grimmer's Avatar
I should elaborate...
There is the throttle position sensor (#11) and there is the secondary throttle position sensor (#10) . The latter is the one that tells the ECM what position the secondary throttle butterflies are in. The latter is the higher of the two and the feedback circuit exits the sensor body through the connector on the top. Both of these sensors are on the left side rear corner of the rear throttle body. You'll have to lift the tank to see them.
There has been much discussion about the wires rubbing the bottom of the tank. On my Vee2 it was the wires as they exited the secondary throttle position connector that were at risk of rubbing on the tank. If the signal wires are fully or partially shorted to ground (or to each other) the ECM will get no signal or a false signal and cry about it.
I would start with a physical inspection of the wires on that connector.
Do you have a service manual?
Having trouble with site attaching photo... I will attempt to edit the photo into the post.
File Type: jpeg Resized_20190317_003558_1552805346791.jpeg (956.9 KB, 21 views)
Grimmer is offline
post #5 of 18 Old 03-17-2019, 02:44 AM
Grimmer's Avatar
It is giving me a "page can't be displayed" error when I try to manage attachments.
Let's try this...
File Type: jpeg Resized_20190317_003558_1552805033798.jpeg (956.9 KB, 15 views)
Grimmer is offline
post #6 of 18 Old 03-17-2019, 12:22 PM
Was the wiring loom in question, replaced for the associated recall?
post #7 of 18 Old 03-17-2019, 01:33 PM
blaustrom's Avatar
It's this set of wires that could be the problem. I put extra protection around them and tied them down good:
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #8 of 18 Old 03-17-2019, 05:17 PM Thread Starter
NVDucati's Avatar
Hi, ECU swapped, yes. The battery is original. It hasen't given any sign of trouble, the volt meter reads 14.1 but I have not had it tested for crank amps.
But I'm willing to swap it for a nearly new lithium that I have in my Honda as a test. Thanks
Member: AMA
NVDucati is offline
post #9 of 18 Old 03-17-2019, 05:22 PM Thread Starter
NVDucati's Avatar
Thanks. Those suspect wires were checked but deemed okay and just got some padding. But I got that all done very early on in the episode, so I'll check them again.
Big B likes this.
Member: AMA
NVDucati is offline
post #10 of 18 Old 03-17-2019, 05:35 PM Thread Starter
NVDucati's Avatar
Grimmer, No I don't have a service manual. (both your photos did publish) But I understand what you are saying.
You prompt a question:
I read somewhere that with the airbox exposed you can see the butterflies open and close when you turn on the key as a part of the pre-test. Do you know if that is true?
Also I will definitely check all the physical connections and wiring.
I'm still puzzled that it takes a few miles for it to fail. I guess that could be exposed wires heating up from partial contact, huh.
Member: AMA
NVDucati is offline
DL1000 How to adjust the Secondary Throttle Plates handyhiker Maintenance How-to 50 12-23-2015 11:51 PM
K7 Technical: DYI throttle valve synchronization ikoflexer DL650 and DL650A - 2004 to 2011 28 12-08-2013 08:57 PM
Throttle valve synchronization DL650 K9 Juerg V-Strom Service and Maintenance Questions and Discussions 0 12-21-2009 01:04 AM
Is it true? Do i need to bring 08 wee in for Throttle Valve Sync? DustyMcNuggets DL650 and DL650A - 2004 to 2011 35 01-25-2009 05:55 PM
Throttle Body and Intake Modifications AusStrom DL1000 from 2002-2012 11 09-09-2008 09:22 PM
