Clutch slave cylinder leak - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 13Likes
post #1 of 27 Old 02-22-2019, 05:10 PM Thread Starter
I am looking for a rebuild kit (seals) for a 2014 dl1000 clutch slave cylinder. Don't see any specific for my bike. Anyone know if it has the same clutch slave as the 2008-2012 ? I see those kits available?
Thanks
Sent from my SM-G900V using Tapatalk
stone is offline
post #2 of 27 Old 02-22-2019, 05:30 PM
Extremely unlikley it needs rebuilt, just has some particulates which got past the seal. Think exactly how a fork seal start leaking, rarely is the seal bad. I'd drain out the slave, and clean everything up really really good, or while you're in there I guess you could just replace everything. This is one of the reasons I no longer wish for a 1000 Strom, Suzuki has an absolutely HORRIBLE design for the hydraulic clutch systems.
pvwheeler and stone like this.
post #3 of 27 Old 02-22-2019, 05:59 PM
Stone, the items you'll want to replace for clutch slave cylinder rebuilding are:
Suzuki part numbers as per MR Cycle:
1)23166-06G00 $8.91 cover
2)23163-06B00 $5.15 cup
You didnt ask for diagnosis, frequency of failure, or anything other than a kit. The parts are available from Suzuki, as separate parts, not as a kit.
Ive rebuilt many clutch slave cylinders(master cylinders as well, nothing to it but to do it.
MAZ4ME is offline
post #4 of 27 Old 02-22-2019, 09:32 PM
Sounds like the slave unit on a Ducati 900SS. They were famous for failing. i towed a friend home a few times. I think there were problems on some Guzzis too.
Maybe they all came from Piece of Crap Industries? They like to bid low.
post #5 of 27 Old 02-22-2019, 10:02 PM
blaustrom's Avatar
Stone,
before you put it all back together look at the links in this post: https://www.stromtrooper.com/5336633-post6.html
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #6 of 27 Old 02-22-2019, 10:43 PM Thread Starter
Thanks for the replys, I'll take it apart tomorrow, see if I can just clean it up or need seals. As for symptoms it's a slow leak of brake fluid from the bottom of the slave. Have to top off the master every couple hundred miles.
stone is offline
post #7 of 27 Old 02-23-2019, 09:59 AM
STCorndog's Avatar
While not the smartest design, the engine came from a sport bike.
In 100,000 miles, mine only ate one slave cylinder.
STCorndog is offline
post #8 of 27 Old 02-23-2019, 08:14 PM
KTM and Beta have mastered the hydraulic clutch systems, they have few issues ever.
post #9 of 27 Old 02-23-2019, 08:59 PM
Big B, I dont view KTM and Beta as mainstream/volume motorcycle brands, at least not in the US.
Among the 4 Japanese brands what leads you to believe that Suzuki hydraulic clutch systems are inferior to the others?
Is it possible that some owners never flush or change their clutch hydraulic fluid, and this lack of maintenance leads to problems?
Ive flushed many brake systems on bikes, only to show the owner that their clutch fluid was like black molasses. They were totally unaware--or didnt give a sh** about their clutch fluid. Change/flush the clutch fluid, lube the lever pivot, and all was better with reduced lever effort.
notacop likes this.
MAZ4ME is offline
post #10 of 27 Old 02-23-2019, 09:45 PM
I'm so guilty of ignoring the fluid flush on brakes and appreciate how much better it is with a new load of fluid. the Clutches couldn't be any different.
I know the Guzzi flush is a PITAS, I helped a friend with his V1100 Sport and Stelvio a few times. Probably why it's an ignored procedure.
Clutch slave cylinder dust seal(new version) question. mistico DL1000 from 2002-2012 24 08-04-2014 06:44 PM
DL1000 clutch won't release Stobie V-Strom Service and Maintenance Questions and Discussions 14 12-28-2012 04:01 AM
Clutch slave cylinder R&R Scott E. Bonds V-Strom Service and Maintenance Questions and Discussions 8 02-02-2012 12:38 PM
Leaking slave cylinder? pryde V-Strom Service and Maintenance Questions and Discussions 3 09-20-2009 08:42 PM
Replaced Slave Cylinder... No I Have No Clutch!!! WARainman Maintenance, Tech and Products. 12 05-26-2009 03:50 PM
