Won't start - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 02-15-2019, 05:46 PM Thread Starter
Johnny Rowland's Avatar
Won't start
I'm having s rough time! 2014 Dl1000a won't start. New starter switch and relay, started twice now nothing? If I jump from battery to starter, starts right up. Any suggestions?
Johnny Rowland is offline
post #2 of 9 Old 02-15-2019, 06:41 PM
use a multimeter, and follow the power flow. is the relay clicking at all? start by disconnecting the lead to the starter, then attaching one end of the multimeter to battery ground, and the other end to the following in order: battery side switch wire, relay side switch wire (click the switch to see if power is getting through), at the relay, check both switch side and ground side of the relay power (switch on). then finally check the starter cable if all is good. you may need to use a paper clip or something very thin as a probe to the back side of the connectors to get a good reading.
what this will tell you is where power is stopping on it's path to the low power side of the relay, and then on the high power side. If you get nothing at the starter side of the relay but everything else is good, then i would suspect a bad ground somewhere.
And of course, ignition on when testing so the relay and switch have power...
--Joel
joelrf600r is offline
post #3 of 9 Old 02-15-2019, 06:42 PM
I don't know enough about the DL1000 or the 2014 model year to say with any certainty but the first thing that came to mind was the fuse...
Is your side stand down? Clutch pulled in? In natural?
gdrew is offline
post #4 of 9 Old 02-15-2019, 06:46 PM
Motorpsychology's Avatar
Kill switch ON? Don't ask me why that's the first thing I questioned!
Check both power cables at both ends for looseness. Is the bike kept outside mostly? Possibly one or both cables have corroded inside the insulation to the point there is little or no contact. Even though you might have lights, horn, etc, good connections and continuity are necessary for the starter. If you have a multimeter, check both cables for continuity by putting one probe on each end of the cable (Ignition off). There should be zero ohms resistance. Any resistance or infinite (pegged the needle) means it's bad and needs to be replaced. The starter relay may be bad. Jump the relay to see if it clicks- it should. If it doesn't, replace it Caution: do not apply long continuous voltage to the relay as this may burn out its internal coil. With a multimeter, Check the relay's coil by putting the +probe on the post with the battery lead and the - probe on the post with the starter lead. It should be between 3-6 ohms; outside of that, replace it.
18 wheels move the cargo, 4 wheels move the body, 2 wheels move the soul -unknown
“Of all the paths you take in life, make sure a few of them are dirt.” - John Muir
I visited the Air & Space Museum- didn't see a thing...
Motorpsychology is offline
post #5 of 9 Old 02-15-2019, 06:55 PM
DerStrominator's Avatar
My clutch switch broke on my 2014 DL1000A at around 50,000 miles. Short the circuit at the attachment point on the clutch lever and you will know. It was easy to diagnose and fix. Less than $20. Good luck.
DerStrominator is offline
post #6 of 9 Old 02-15-2019, 08:19 PM
Rolex's Avatar
Is there anything displayed on the dash where the gear position indicator is ?
Have you made any other changes to the bike EG; added electrical items or repositioned your handlebars.
By shorting from the battery to the relay you are bypassing all safety switches like the kill switch and clutch switch, the kick stand switch should only play a part if the bike is in gear not in neutral.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #7 of 9 Old 02-25-2019, 04:34 PM
Crickets! Where did he go?
2015 DL1000 ADV
2thDr is offline
post #8 of 9 Old 02-25-2019, 06:31 PM
Bugzy's Avatar
Maybe it was the kill switch, and he was too embarrassed to admit it.
I remember one time with my Vee, I had installed new levers and the switch setting on the clutch was set to 1, which wasn't enough to activate the clutch switch, so bike would not start. Greywolf (RIP) fixed that for me in .05 seconds after suggesting I switch it to 2.
Bugzy is offline
post #9 of 9 Old 02-25-2019, 06:51 PM
Rolex's Avatar
I remember a guy posted photos of his bike when it would not start, I could clearly see the kick stand was down and there was no neutral light showing on the dash, things happen.
2014 V2, Snoopy
Rolex is offline
Engine won't start, FI light comes on R-2 DL1000A - 2014-2016 49 07-08-2015 12:21 PM
CHK light and no start FLS DL650 and DL650A - 2004 to 2011 3 05-22-2014 01:13 PM
Hard to start, befuddeling Rogue Reaper V-Strom Service and Maintenance Questions and Discussions 4 11-21-2013 11:19 PM
2005 V-strom 650 won't start skiphunt DL650 and DL650A - 2004 to 2011 12 05-23-2010 08:35 PM
Help-wouldn't start before big trip Peterbob V-Strom Service and Maintenance Questions and Discussions 6 06-14-2008 02:21 PM
