riser/bar backs 2014 to 2018 DL1000 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 15 Old 02-14-2019, 10:43 PM Thread Starter
Does anyone have a Vee2 with the riders that also move the bars back (I think they're 30-mm up and 22-mm back) installed on their bikes who live ion Ontario, Canada? Toronto?
Thanks much
Motocanada is offline
post #2 of 15 Old 06-07-2019, 11:35 PM
Webfors's Avatar
Bumping this thread instead of starting a new one.
I'm thinking of buying the 30mm risers to improve posture and stand up riding.
Anyone run into issues throwing on 30mm risers?
Two wheelz for realz!
Webfors is offline
post #3 of 15 Old 06-07-2019, 11:45 PM
V-Tom's Avatar
I think you are going to want to install longer brake and clutch lines. Not a big deal in the long run but a bit fiddly routing lines, bleeding etc.
(This based on 2015 DL1000. Perhaps you bike has longer hydraulic lines.)
..Tom
SMIDSY detailed report.
V-Tom is offline
post #4 of 15 Old 06-07-2019, 11:46 PM
V-Tom's Avatar
(This based on 2015 DL1000. Perhaps your bike has longer hydraulic lines.)
..Tom
V-Tom is offline
post #5 of 15 Old 06-08-2019, 12:08 AM
Webfors's Avatar
Thanks Tom.
What size risers are you running?
I'm thinking of going with the Bikemaster option that provides 4 different lengths in one kit. That way I can start with the 1 inch, then go higher when I decide to play with the cables.
https://fortnine.ca/en/bikemaster-handlebar-risers
Webfors is offline
post #6 of 15 Old 06-08-2019, 08:36 AM
V-Tom's Avatar
I don't recal for sure as I got the risers in late 2006 or 2007. I think they are inch up and inch back. I could have moved the lines around a bit to make room but they would still be tight at the extremes and I don't like that idea.
..Tom
V-Tom is offline
post #7 of 15 Old 06-08-2019, 04:37 PM
JustAnotherDude's Avatar
2" Rox risers without new cables. Route cables behind triple clamp for slack. Sorry about the rotation on the first picture, forum won't let me rotate it.
Webfors likes this.
2014 DL1000
JustAnotherDude is offline
post #8 of 15 Old 06-11-2019, 12:12 PM Thread Starter
did you need to take off the triple claimp or did you just take off the switches and pass the tries through between the steering stem and the fork leg?
post #9 of 15 Old 06-11-2019, 12:21 PM
Webfors's Avatar
I suspect 30mm might be fine without any changes if all you needed to do is reroute cables for 60mm.
Webfors is offline
post #10 of 15 Old 06-13-2019, 03:12 PM
Switches were off because of putting new bars on along with risers.
2014 DL1000
Spring 2018 - Romney, West Virginia - May 18 - May 20, 2018 Dirt_Dad Events 162 01-11-2019 07:38 PM
2014 centerstand, seat and crash bars fit 2018? MeefZah DL1000A - 2017+ 6 05-11-2018 12:33 PM
2018 Farkles and Great Upgrades for the DL650 and DL1000 SV Racing Parts SV Racing Parts 1 04-19-2018 11:26 AM
