Removing the Exhaust System - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 2 Post By steve85248
post #1 of 4 Old 01-16-2019, 11:38 AM Thread Starter
My bike came w/ a Gianelli exhaust system, and while its pretty and sounds nice, it is an interference fit with a factory center stand and it looks like it will be a problem fitting a skid plate. Since I think the center stand is more important to me than a pretty exhaust system, I'm going to remove it and put the OEM one back on.
What major components do I have to remove in order to swap these ex systems? The manual wants me to remove the body panels and rear shock. Is it necessary to pull the shock absorber? How do I support the bike w/ no shock? Right now it is held upright by a rear stand that engages small aluminum spools on the rear wheel axle. It almost looks like removing the tank is necessary but the manual does not mention this.
Ratchet is offline
post #2 of 4 Old 01-16-2019, 01:17 PM
Don't have any experience with your after market exhaust, but with my Arrow racing collector (cat removed) and Mivv slip-on I did not remove the shock. If you need to, you can support the rear of the bike with chains or straps to an overhead joist or similar.
Sent from my Moto Z (2) using Tapatalk
2015 DL1000 ADV
2thDr is offline
post #3 of 4 Old 01-16-2019, 09:22 PM
Seems I removed my shock when the bike was on the centerstand with no issues.
Ah, you seems to be centerstandless. Therein lies the problem. You need a sky hook.
I've hung bikes from the rafters of the garage before.
post #4 of 4 Old 01-16-2019, 11:06 PM
steve85248's Avatar
A strong step ladder straddling the back of the bike using ratchet straps to lift and hold. I use a commercial AL folding step ladder rated at 300lbs.
notacop and Hatchi like this.
steve85248 is offline
Help removing mar marking on the brushed aluminum exhaust covers Houston-Stromtrooper Maintenance, Tech and Products. 1 02-16-2014 09:46 PM
06 exhaust system fit an 07? FJR/V-strom trooper DL650 and DL650A - 2004 to 2011 8 09-05-2008 02:47 PM
