ABS fuse for 2014 1000 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By OregonMike
post #1 of 7 Old 01-13-2019, 12:16 AM Thread Starter
OregonMike's Avatar
Cant get search to cooperate.... what fuse do I need to yank to turn off ABS? May be doing a gravel ride and would like it off.
Also, does pulling that fuse disable the entire cluster too? Hope not...
Also on this note, couldn't a person just run a switch from the bars or anywhere on the bike, to the wire going into the fuse and splice it in... so switch off, just like pulling the fuse... switch on, business as usual??? Seems much less complicated that running power to relays and switches and etc etc etc...
Thanks all...
Rolex likes this.
THE LIST:
99 TL1000R - Blue and White
02 GSX-R1000 - Blue and white
94 RF900R - Black - SOLD to get....
14 DL1000 - Cool tan color!!! WOOT
OregonMike is offline
post #2 of 7 Old 01-13-2019, 05:18 PM
Rolex's Avatar
You need to pull the 25a ABS motor fuse.
If you pull the 15a valve fuse you will lose your instruments.
I basically replaced that fuse with a inline fuse and a switch (it's posted on here) no need to cycle the ignition switch with a switch, just off and on, all will be good.
https://www.stromtrooper.com/4352217-post48.html
try this, others have done it in other ways too.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #3 of 7 Old 01-14-2019, 02:19 AM Thread Starter
OregonMike's Avatar
Cool.... What gage wire did you use??? Thanks for the into...
THE LIST:
post #4 of 7 Old 01-14-2019, 12:31 PM
Toshbar's Avatar
Full writeup here, with parts list. https://www.stromtrooper.com/dl1000a...tallation.html
I don't know where my pictures went but I can send them to you if you want.
2014 One Thou Pow!
Toshbar is offline
post #5 of 7 Old 01-14-2019, 02:21 PM
Rolex's Avatar
I suggest you use a DC Cable Sizing Tool once you know the length of cable you will use, it should be rated to handle 25 amps although my testing tells me it never gets anywhere near that.
I fitted the switch near the rear brake master cylinder so it is a very short run and I'm still using a 15a fuse without any troubles.
2014 V2, Snoopy
Rolex is offline
post #6 of 7 Old 01-14-2019, 05:09 PM Thread Starter
OregonMike's Avatar
^^^yes please^^^
THE LIST:
post #7 of 7 Old 01-14-2019, 08:25 PM
Toshbar's Avatar
^^^yes please^^^
I added all the photos to the end of my thread, since I can't edit the original post.
2014 One Thou Pow!
Toshbar is offline
Fitting a 12V accessory outlet - best options DCSF Techy World! GPS, Electronics, etc 37 05-13-2019 09:45 PM
Suzuki V-Strom 1000 Endurance Test York DL1000A - 2014-2016 4 06-09-2017 07:29 AM
Fuseblock ?? bmwlarry DL650 and DL650A - 2004 to 2011 8 07-13-2015 02:14 AM
Major Electrical Fault DL1000 Sheds DL1000 from 2002-2012 58 05-04-2014 06:48 PM
Magacin.dk V-Strom 1000 review zedex9r DL1000A - 2014-2016 1 02-25-2014 08:43 PM
