Cold clutch? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
  • 1 Post By stone
  • 5 Post By realshelby
post #1 of 6 Old 12-26-2018, 07:04 PM Thread Starter
Cold clutch?
This is my 1st bike with a hydraulic clutch. Seems like when it's cold out the clutch throw changes. I often work 3rd shift and get on the bike in the morning when it's below freezing. Sometimes it feels like the the clutch is still a little engaged with lever pulled all the way in. The owners manual says there is no adjustment and it's self adjusting. After the bike warms up and I've ridden a ways seems like it's back to its normal throw. Any thoughts? Probably just how hydraulic fluid behavior in the cold.
Thanks
Sent from my SM-G900V using Tapatalk
rider1 likes this.
stone is offline
post #2 of 6 Old 12-26-2018, 07:09 PM
newride's Avatar
It should get back to normal very quickly. For me, it is basically OK once I am out of the driveway.
newride is offline
post #3 of 6 Old 12-26-2018, 07:11 PM Thread Starter
Yeah I have found if I cycle it a couple of times it helps.
stone is offline
post #4 of 6 Old 12-26-2018, 11:13 PM
Rolex's Avatar
Cold motor oil can also make the clutch feel that way.
As the motor oil warms up the clutch plates will spin more freely.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #5 of 6 Old 12-27-2018, 09:07 AM
As long as you can put it in first gear with the clutch pulled in, and the bike doesn't try to run away on you, it is more or less normal. While there is no mechanical adjustment, you can make the system work better in many cases by flushing and then filling with new fluid. Then a really good bleeding of the system. Don't know what year your bike is. Even if a 2018 it could have fluid over a year old by now. Clutch systems put a LOT more contamination into the fluid than brake systems do. In my opinion they should be flushed every year. It will pay off in the long run!
V-Tom, stone, Lrobby99 and 2 others like this.
realshelby is offline
post #6 of 6 Old 12-27-2018, 01:23 PM
Perhaps your Strom is trying to tell you something?
06 Wee Clutch Engagement Problem tetsuo69 DL650 and DL650A - 2004 to 2011 7 06-05-2015 11:04 AM
Need Clutch Help Strange Dog DL1000 from 2002-2012 12 03-25-2015 11:11 PM
I am sorry but, another frigging clutch question. carlrf DL1000 from 2002-2012 33 10-29-2014 10:01 AM
DL1000 clutch won't release Stobie V-Strom Service and Maintenance Questions and Discussions 14 12-28-2012 04:01 AM
Extended clutch arm? SRTeric DL650 and DL650A - 2004 to 2011 1 09-02-2012 02:47 PM
