Need a little help. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 14Likes
post #1 of 17 Old 12-24-2018, 05:32 PM Thread Starter
HootStrom14's Avatar
Need a little help.
Can someone tell me what originally goes in this bolt hole and is it threaded?
I have a rave tech skid plate on mine and I noticed on a trip this weekend that the bolt was hanging out. The bolt itself looks fine but the threads on the skid plate are “flattened” implying that it either stripped or seized and broke loose. Inside the bolt hole it’s really smooth with very fine ridges implying that there were threads there but...maybe not.
It’s just been so long since I have put this on I can’t remember
Jes
2014 V-Strom DL1000
"Dress for the slide, not the ride!"
HootStrom14 is offline
post #2 of 17 Old 12-24-2018, 05:52 PM
That's not threaded on my 650, that's where the long bolt goes through for my Weld86 skid plate to mount.
notacop likes this.
post #3 of 17 Old 12-24-2018, 05:52 PM
That is the sidestand mounting lower frame bolt. The bolt has sheared off and it can be extracted from the threaded frame boss to which it is mounted. There is an upper bolt for the mount about 2 inches higher and to the right. If that upper bolt shears, then the bike will be on its side real quick.
Suzuki part No. 01550-1235A $2.34
MAZ4ME is offline
post #4 of 17 Old 12-24-2018, 06:16 PM
Big B, I was going by the OP's reference to a '14 DL1000 in the "About Me" area.
The view is exactly as my '14 DL1000. The long engine-to-frame thrubolt head is shown above it with the threaded spacer behind the bolt head.
Note the hydraulic clutch slave cylinder--'14 DL1000 feature.
HootStrom14 likes this.
MAZ4ME is offline
post #5 of 17 Old 12-24-2018, 06:22 PM
Roger that, I never argue with your expertise and wisdom....plus I'm one of those converted 650 guys.
HootStrom14 and MAZ4ME like this.
post #6 of 17 Old 12-24-2018, 06:23 PM Thread Starter
The bolt has not sheered off. In fact I’m holding a beautifully pristine bolt in my hand that backed out. Upon further inspection, it backed out enough over time that my side stand mount shifted up on the front, causing a sag in my bike (which originally led to this finding) and I realize that what I’m looking at is the very top of the hole that is being covered by the up shifted sidestand bracket. I’m about to dismantle it again and push it back down so I can get the bolt back in.
Thanks everyone for the help!!!!!
Gert likes this.
Jes
2014 V-Strom DL1000
post #7 of 17 Old 12-24-2018, 06:26 PM Thread Starter
And praise the Powers that be that it is not worse than that!!! It’s a Christmas miracle!!!!
Jes
2014 V-Strom DL1000
post #8 of 17 Old 12-24-2018, 06:57 PM
A good reminder to all of us that during oil changes or other frequent maintenance, that we check all fasteners for proper torque or at least that the feel tight to a wrench...I needed that reminder for sure.
Sent from my Moto Z (2) using Tapatalk
2015 DL1000 ADV
2thDr is offline
post #9 of 17 Old 12-24-2018, 06:59 PM Thread Starter
Absolutely! This has been an excellent reminder of that “routine” maintenance!
MAZ4ME likes this.
Jes
2014 V-Strom DL1000
post #10 of 17 Old 12-24-2018, 07:02 PM
Sorry Hoot, I saw that top pic and didnt see the hole, looked like a sheared bolt to me. You had good luck with that bolt.
I'd loosen that skid plate, loosen the upper bolt, then install the lower with Blue loctite and torque to 32 ft-lbs. If you can have the bike held up, I'd also loctite and torque the upper bolt the same way, then re-tighten the skid plate. The 32 ft-lb spec is from my Suzuki Service Manual.
MAZ4ME is offline
