2014 Headlight - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #1 of 28 Old 12-04-2018, 08:34 PM Thread Starter
Johnny Rowland's Avatar
2014 Headlight
I'm tired of problems with my 2014 Suzuki v strom 1000 starter switches!does anyone do a relay kit for H7 bulbs. To take headlights off starter switch? Or diy?
Johnny Rowland is offline
post #2 of 28 Old 12-04-2018, 08:42 PM
Administrator
Few problems have been reported with the 2nd gen 1000's concerning this, EasternBeaver doesn't even feel the need to make a relay kit for the new 650/1000. Might be worth sending Jim an email and see what he says? Hopefully somebody here can help you, are you sure it isn't just corrosion occurring in the switch assembly from water intrusion?
2015 DL650 XT "Fred"
1997 Honda Valkyrie 1500 custom “Fiona”
post #3 of 28 Old 12-04-2018, 10:52 PM
From EB:
"NEW DL1000s from 2014 on and 650s from 2017 on:|-:|these new models have Non-H4 headlights and different wiring in many areas. This means the H4 Relay Kit and the ABS Cut Adapter won’t fit. I have some Kits and Adapters specifically for these models:|here."
https://easternbeaver.com/Main/Bike_...om/vstrom.html
Big B likes this.
Hatchi is offline
post #4 of 28 Old 12-28-2018, 06:56 PM
steve85248's Avatar
Took my beak off to install the Signal Dynamics modulator. All specs say the 2014 Vee is H7 bulb which is the harness I bought. Found out I have H9 and it won't fit. Am I missing something? The really odd part is the shop manual states my low is an H9 and high is H7. The pic below is of my high beam light.....
File Type: jpg 15460426692078639126334701210008_1546042691449.jpg (217.8 KB, 17 views)
steve85248 is offline
post #5 of 28 Old 12-28-2018, 11:56 PM
Location: Ann Arbor, MI and San Miguel de Allende, Mexico
Yes, H9 and H7. They make an adapter that runs to pigtails and you can buy replacement H9 and H7 sockets on Amazon . When I install my Signal Dynamics in my Mexico bike in a few weeks, I'm going to splice the output of the SD to the new sockets and then plug the new sockets into the headlights From what I've seen online, I'm using ceramic sockets because the plastic ones have been known to melt.
To be really clear: I haven't done this yet myself but I will be soon.
On my US bike, a 2018, I bought the same harness you did. I wound up cutting, splicing, and soldering to get it in.
Vinnie
Sent from my Nexus 5X using Tapatalk
Currenv is offline
post #6 of 28 Old 12-29-2018, 10:35 AM
steve85248's Avatar
So the high is an H9 and the low is an H7. The shop manual for our bike is incorrect it has it backwards. I wonder what else I'll find incorrect in the manual.... Also, if the SD harness goes inline, I don't understand why it has 4 female and two male connections. Seems to have an extra high and low female but I have to dig more into the diagram today.
post #7 of 28 Old 12-29-2018, 11:51 AM
steve85248's Avatar
I think this will work but I'll call signal dynamics on Monday to be sure. If I cut this harness in half I have one male and one female H9 pigtails. I can then cut the high beam H7 male and female off the SD harness and solder on the pigtails I made. Thoughts? Suggestions?
https://store.ijdmtoy.com/Heavy-Duty...ic-adapter.htm
post #8 of 28 Old 12-29-2018, 03:36 PM
I'm not sure which is the HI and the H9... It's been too long since I did my 2018 and I don't remember. It's one of each, though.
Vinnie
Currenv is offline
post #9 of 28 Old 12-29-2018, 07:58 PM
V2man's Avatar
Our workshop manual says the same.
BUT our owners manual has the H7 as the low & H9 as the high which is correct.
Cheers
Rolex likes this.
2014 DL1000A 2014 -
2012 DL650L2 2013 - 2014
2007 DL1000 "Bowser" 2009 - 2013
V2man is offline
post #10 of 28 Old 01-08-2019, 09:19 PM
steve85248's Avatar
Headlight modulator is now installed. Big pain in the ass on the vee. There are no plug-n-play harnesses that fit the 2014 vee. You have to buy an open end harness and solder it all in. https://youtu.be/USiQzrqZQCA
2013 DL650A speedometer and odometer way off jvazquez General V-Strom Discussion 6 08-27-2018 09:30 PM
HID Projector retrofit into Headlight assembly AceRider General V-Strom Discussion 55 03-05-2016 08:53 PM
