2014 Headlight - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #11 of 32 Old 01-14-2019, 10:11 PM
Location: Ann Arbor, MI and San Miguel de Allende, Mexico
Confirming shop manual error
I just installed my Signal Dynamics on my 2014 1K today. I can confirm that the shop manual is wrong -- it has the H7 and H9 bulbs reversed.
Also, since I pulled the nose to do this (I uninstalled an LED low beam lamp the PO had installed because the light emitter was cocked 45 degrees and doing that was a lot easier on the bench), I wanted to check the lights' aim. The low beam was a tad high but turning on the vertical adjust screw seemed to have no affect. Anyone else had to deal with this?
Thanks,
Vinnie
Originally Posted by steve85248 View Post
Headlight modulator is now installed. Big pain in the ass on the vee. There are no plug-n-play harnesses that fit the 2014 vee. You have to buy an open end harness and solder it all in. https://youtu.be/USiQzrqZQCA
Currenv is offline
post #12 of 32 Old 01-14-2019, 11:54 PM
blaustrom's Avatar
Originally Posted by Johnny Rowland View Post
I'm tired of problems with my 2014 Suzuki v strom 1000 starter switches!does anyone do a relay kit for H7 bulbs. To take headlights off starter switch? Or diy?
Since EB does not offer the relay kit I made my own for the H9 high beam, with some fighting since the H9 pigtail I bought did not fit without modification. However high beam is off most of the time, so this relay has little practical effect other than maybe a brighter light.
The low beam H7 is more of a problem since it is connected inside the closed low beam housing and the power is routed outside and to an obscure connector I have been unable to find. Have since given up on searching for it.
It is a 2 pole connector, sealed, with the number 11156 on one side. If anybody knows wo make these connectors or where to get them, I like one please.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #13 of 32 Old 01-15-2019, 10:54 AM
steve85248's Avatar
Installing LED headlamps is not legal with a modulator in the US. Reason is we can only modulate from a 30% to 100% brightness. When you use LED the lamp turns off resulting in 0% to 100%. SD engineers are working on an LED modulator that will allow for a 30% on the low end.
steve85248 is offline
post #14 of 32 Old 01-15-2019, 01:48 PM
Rolex's Avatar
This is my V2 headlight story.
I purchased my V2 used and noticed the PO had a headlight globe fitted by his local dealer.
After a few weeks of ownership I lost my low beam, I thought back to his globe change and thought I found the reason he had sold the bike it must have ongoing low beam problems.
When I opened things up to change the globe the plug on the back of the globe had melted, things had obviously gotten hot.
Having a good look I found the brass female spade fittings had no tension, they were soft.
I determined when the original globe was changed they had wobbled the plug enough to spread the contact points, this caused heat and that heat in turn soften the fittings causing more heat and melting the plug.
I did not change the globe but I did replace the spade fittings and all has been good since.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #15 of 32 Old 01-16-2019, 06:07 PM
Check with cycleterminal.com He is very knowledgeable and has tons of connectors. Also Tripage LED or TST Industries might help.
Sent from my Moto Z (2) using Tapatalk
2015 DL1000 ADV
2thDr is offline
post #16 of 32 Old 01-18-2019, 12:10 AM
Toshbar's Avatar
I did a 35w HID low and LED high, which takes a third of the load off all contacts.
2014 One Thou Pow!
Toshbar is offline
post #17 of 32 Old 01-18-2019, 11:35 AM
V-Tom's Avatar
FWIW I have replaced low-beam bulbs twice on my 2015 DL1000. The bike currently has just short of 159,500 km / 99,090+ miles.
On my 2006 DL650 until I parted with it with over 202,000 km/ almost 126,000 miles I never replaced a single headlight bulb.
On my 2012 DL650 that I sold with over 139,500 km/ 86,700+ miles I never replaced a headlight bulb.
On the 2006 DL650 I had to take apart and clean the starter switch assembly, I think somewhere around 160,000 km/100,000 miles (but don't remember the mileage for sure.)
None of these Stroms ever had a relay kit for the headlights so I guess I am just lucky.
..Tom
2015 DL1000 New July 2015 175,000+ km, 108,500+ miles.
SMIDSY detailed report.
V-Tom is offline
post #18 of 32 Old 02-04-2019, 01:40 PM
I fixed the headlight issue just by cleaning the wire terminal and tightening it. The connector is behind the radiator. I'll try to get pics of the connector when I get the bike out of the storage in a couple of days.
AlexC is offline
post #19 of 32 Old 02-07-2019, 08:51 AM
pics for headlight fix
here are some pictures of what I did to fix the headlight problem. It might not be the solution for all of you, but this is what worked for me.
AlexC is offline
post #20 of 32 Old 02-07-2019, 09:07 AM
more pics of the process.
AlexC is offline
2013 DL650A speedometer and odometer way off jvazquez General V-Strom Discussion 6 08-27-2018 09:30 PM
HID Projector retrofit into Headlight assembly AceRider General V-Strom Discussion 55 03-05-2016 08:53 PM
