Gear position indicator ‘delay’ - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 12-01-2018, 12:28 PM Thread Starter
Gents, long time lurker, first time poster...
Went out on the bike and whenever I shifted into neutral the gear position indicator would go blank. It’s only blank when in neutral, but oddly the neutral light still works as normal. The revs at neutral are also slightly higher than normal.
I did all the usual things, and have cleaned behind the front sprocket cover where I believe the gear position sensor is. This seems to have worked, to an extent.
It now shows neutral, but only after a delay of 3 to 4 seconds, rather than instantly as when working properly. The revs are also higher than they should be at idle until the N is shown on the gear position indicator.
Any thoughts? Bit stumped here. Bike is a 2016 with 17,000 miles on.
Tim1989 is offline
post #2 of 4 Old 12-01-2018, 03:34 PM
bosnjo's Avatar
Mine is '18 model and does the same since new.
2017 DL1000 White
2014 DL1000 Red (sold)
2012 DL650 White (sold)
bosnjo is offline
post #3 of 4 Old 12-01-2018, 05:13 PM
Bugzy's Avatar
The GP switch (assuming this is Gear Position) is located inside the clutch assembly, you would need to take that apart to replace it, but it may be a wire connecting to it that has a loose connection since it seems to be working most of the time.
Might be time to get a manual if you do not have one and see if you can trace the wires coming out of there.
Any warranty left on the bike?
Bugzy is offline
post #4 of 4 Old 12-01-2018, 07:30 PM
Rolex's Avatar
Ensure your earth cable is clean and tight at the motor, there was a recall for this on early bikes, did you have it done ?
Check your battery connections (this should be done from time to time anyway) and any other connectors for corrosion.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
Riding Gear Thread: Post your gear Wallygator General V-Strom Discussion 10 11-15-2014 09:19 AM
Extended gear lever Mxteam Australia-New Zealand 14 10-04-2014 08:44 AM
Cheap $25 gear position indicator clyde1952 DL1000 from 2002-2012 16 12-31-2013 02:34 PM
