Rear wheel spacer (2014) needs replacement - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 9Likes
post #1 of 12 Old 11-19-2018, 05:18 AM Thread Starter
Question Rear wheel spacer (2014) needs replacement
After 21000 km my front drive chain sprocket is well an truly worn out. The rear sprocket is also worn but not so much. However, the wheel spacers are both worn more that is accepatble. Any good source for buying new ones?
Sandstorm is offline
post #2 of 12 Old 11-19-2018, 06:08 AM
To have chain and sprockets wear out in 21,00k you must be riding in a terrible environment. My first set lasted nearly 50,000k. Always replace them all as a set.
ozbass17 is offline
post #3 of 12 Old 11-19-2018, 07:29 AM
Are you sure the spacers are worn out?
Big B likes this.
realshelby is offline
post #4 of 12 Old 11-19-2018, 08:03 AM
Stromtrooper.com Sponsor
richlandrick's Avatar
Sandstorm,
Are the sprockets worn evenly or have they been worn more on one side than the other? If they are worn more on one side than teh other please post pics. I have not seen any evidence of the Gen 1 chane alignment problem on Gen 2 DL1000s, but you have me wondering.
Regarding your question, teh parts warehouse prices on wheel spacers are not overly expensive. Figure $20 or so per spacer.
Big B and Old Time Rider like this.
richlandrick is offline
post #5 of 12 Old 11-19-2018, 09:59 AM
blaustrom's Avatar
If you think the spacer is worn, which I can't see, what about the bearings? The spacer is clamped stationary by the axle so the only way there can be wear is if the adjacent bearing is causing it. Do the bearings turn without any notchiness and are the dust seals ok?
Do you use any chain lube or why would the front sprocket be "worn out" at 21k km? Show us some pictures so we can appreciate what you are seeing.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #6 of 12 Old 11-19-2018, 11:14 AM
Highwayman2016's Avatar
How does a spacer wear out? It doesn't move. You need to lube your chain more, I just replaced my chain and sprockets at 30,000 miles or 48,000 km and they could have gone way farther but I wanted to change the gearing.
2014 650 Strom
Highwayman2016 is offline
post #7 of 12 Old 11-19-2018, 01:24 PM
Spacers could wear out. Many have a seal surface on them. Should that get grooved or pitted the seal won't hold. Needs replaced.
But at what amounts to 12,000 miles there should not be that kind of wear on the spacers.
Toshbar likes this.
post #8 of 12 Old 11-19-2018, 01:42 PM
Fox
Fox's Avatar
My seal wore out a very long time ago (around 50k miles). I am pretty sure that is what caused my sprocket carrier bearing to fail. After installing a double-sealed replacement bearing, I haven't had any issues - ymmv.
The pictured spacer looks fine to me. I would wipe it off, reinstall it with some clean grease and see how it goes.
Old Time Rider likes this.
Fox is offline
post #9 of 12 Old 11-19-2018, 03:21 PM
Is that your hands in the pic? I know once before someones hands looked so clean to have done wrenching I asked and he said he got his wife to hold the item. If yours what is best hand cleaner to use? My wife will thank you.
Old Time Rider is offline
post #10 of 12 Old 11-19-2018, 04:55 PM
Uh-oh. Your right. His hands are way to clean. Now I'm wondering if the website has been hacked somehow.
Big B likes this.
Front wheel spacer DL650 ABS Navigator DL650 and DL650A - 2004 to 2011 3 09-17-2018 08:27 PM
Do I really Need To Balance My Rear Wheel ? XLonDL650 V-Strom Service and Maintenance Questions and Discussions 24 07-03-2018 03:36 PM
Can someone measure a apart for me? (front wheel spacer thickness) jfman DL1000A - 2014-2016 1 03-31-2017 04:17 PM
Everything Related to Tires (Wheel removal, Repairs, DIY, ETC... Skinnifatkid Suspension and Tire Tech 36 10-28-2015 05:23 AM
Rear wheel too wide for swingarms tshelfer Maintenance, Tech and Products. 31 08-15-2014 07:06 PM
