Rear rack weight limit - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
post #1 of 21 Old 10-08-2018, 10:33 PM Thread Starter
Bad Dad's Avatar
So I got a 50 liter top trunk an would like to know about your experiences with large trunks mounted to the stock rack. This is my first trunk, I'm usually a st. Oll top duffle guy.
2002 DL 1000
Bad Dad is offline
post #2 of 21 Old 10-09-2018, 12:58 AM
Bugzy's Avatar
Do you have the givi rack with the extra support underneath?
Bugzy is offline
post #3 of 21 Old 10-09-2018, 06:42 AM
There's been instances discussed here where the plastic OEM rack has broken. As Bugzy mentions, there is Givi rack that has an extra support tied to the seat frame that takes some of the load off of the plastic rack. That's what I have along with a 47 liter case, and I've carried a watermelon in it without any issue. Aside from weight, you also need to keep in mind the terrain you will be riding on. A heavy weight on a relatively smooth tarmac will do much better than the same weight off road or on an unimproved fire road or gravel road. I'm just about all on-road, so my setup works fine for me.
Houstrom46* is offline
post #4 of 21 Old 10-09-2018, 11:33 PM
Bugzy's Avatar
My bike has been fine on 3 trips up North with a 57 liter box on the back, probably 30 to 50 lbs in it. Lots of gravel and bumps too. Try to keep light stuff in it though, and don't fill it up too full.
notacop likes this.
Bugzy is offline
post #5 of 21 Old 10-10-2018, 11:03 AM
The listed weight limits are lawyer talk. Your experience may vary.
A large box may entice you to carry more stuff though.
post #6 of 21 Old 10-13-2018, 04:53 PM Thread Starter
Bad Dad's Avatar
Just mounted up a used 45 liter monolock and made some supports down to Rick's saddle bag guards
Rolex and Gert like this.
2002 DL 1000
Bad Dad is offline
post #7 of 21 Old 10-14-2018, 02:16 AM
Gert's Avatar
Originally Posted by Bad Dad View Post
... made some supports down to Rick's saddle bag guards
Any close-up pix to see exactly how the supports fit to the racks? Thanx.
Gert is offline
post #8 of 21 Old 10-14-2018, 12:33 PM Thread Starter
Bad Dad's Avatar
Just bolted to the side of stock rack and bolted to Rucks soft bag plate. Also put in some spacers made from some uhmm I had lying around placed between free space under back of rack and the rear fender cover so no flex area anymore.
Gert likes this.
2002 DL 1000
Bad Dad is offline
post #9 of 21 Old 10-14-2018, 12:34 PM Thread Starter
Bad Dad's Avatar
I'll take some pics.
2002 DL 1000
Bad Dad is offline
post #10 of 21 Old 10-14-2018, 02:12 PM
STCorndog's Avatar
I like my weight low and to the sides. I quit running a top box after the Strom and I think the bike handles a lot better....could be my imagination though.
STCorndog is offline
Rear Rack Capacity and Electrical Question Numbercruncher DL1000A - 2017+ 4 03-17-2018 11:21 PM
Factory rear rack removal RatAssassin DL650A - 2012-2016 2 08-12-2017 08:35 PM
Adventure Rack Rear Cross Brace SPD3454 DL650A - 2012-2016 5 07-26-2013 08:05 AM
Givi E36 Weight Limit 2wrdr General V-Strom Discussion 9 10-25-2008 05:47 AM
