Heated grips. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #1 of 11 Old 10-03-2018, 05:33 PM Thread Starter
Feral Donkey's Avatar
Heated grips.
I just got the kit in the mail. What should I wire it to that's keyed? Should I use the hot wire going to the cigarette lighter port? I have my satellite radio, bluetooth transmitter, and phone charger to run off that too. Will that be ok or find another hot wire to mooch off of?
Feral Donkey is offline
post #2 of 11 Old 10-03-2018, 07:25 PM
I would suggest adding an auxiliary fuse box, typically under the seat. Set it up to run off a relay that is powered by a keyed/switched power line like the rear light since the wire runs under the seat on its way to the rear of the bike. Then I'd suggest running your various electrical farkles off that fuse box. Each could have a dedicated circuit. There is some good electrical advice for doing stuff like that over at Electrical Items - LDRiders
2thDr likes this.
Yarz1 is offline
post #3 of 11 Old 10-03-2018, 07:34 PM
Motor7's Avatar
Which ones did you get? Oxfords come with a harness that goes right to the battery. Automatically shuts off when bike is off for more than a few min.
'15 DL650XT
Motor7 is offline
post #4 of 11 Old 10-03-2018, 08:03 PM Thread Starter
I got the Tusk ones. My '06 came with them already on it and they work great. Nice idea on the fuse box.
post #5 of 11 Old 10-03-2018, 09:06 PM Thread Starter
You guys have me thinking. I scored a big bag of relays off Ebay last spring. I can tap into the tail light wire to trip the relay. Then I can wire it directly through the relay from the batery to the grips. Then it won't matter if the tail light circuit doesn't have enough juice. All it's got to do is trip the relay when the key turns on. I can do all my gee-gaws on that. Add some fusable links or a fuse block and the possibilities are endless.
post #6 of 11 Old 10-04-2018, 05:56 PM
bighammer's Avatar
I know on my '18 it says 36W max next to the 12V outlet. That's only 3W of power.
There is a heated grip plug buried under the tank somewhere.
2018 Flee-Strom 1000XT
bighammer is offline
post #7 of 11 Old 10-05-2018, 12:08 PM
Bugzy's Avatar
The Cig Lighter port is only a 3A fuse, it will blow as soon as you turn the heaters on.
I always attach to a fuse block under the seat, a very useful addition to the bike.
2thDr likes this.
Bugzy is offline
post #8 of 11 Old 10-05-2018, 08:17 PM
Eastern Beaver has a great kit, PC-8 I think, with a pre-made harness if you want. I have also used Fuzebox on two long term bikes with no failures.
Sent from my Moto Z (2) using Tapatalk
2015 DL1000 ADV
2thDr is offline
post #9 of 11 Old 10-06-2018, 12:46 AM
larolco's Avatar
I don't know about your particular model, but the old Vees have a dedicated plug in the harness near the radiator just for heated grips. Maybe yours does too. Surely someone out there knows if it does.
DRZ400SK17
larolco is offline
post #10 of 11 Old 10-06-2018, 12:59 AM
nvr2old's Avatar
I had my airbox off last week(On 2018 1000) and saw a spare plug-in under it. Pretty sure its for the grips.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
Heated grips & heated vest too? cforider DL650A - 2012-2016 26 05-19-2017 01:46 PM
Verification of Heated Grips Connector and Wiring Question ajp DL650 and DL650A - 2004 to 2011 7 05-15-2017 10:41 AM
One controller for heated grips and vest? rconti V-Strom Modifications and Performance 7 02-10-2011 12:35 AM
symantic heated grips over original grips Al Gilliland General V-Strom Discussion 5 11-21-2009 12:37 PM
Suzuki Heated Grips Worthless CarbideDude General V-Strom Discussion 20 01-01-2008 09:22 AM
