Bent Handlebars... OE or Aftermarket - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By MeefZah
  • 1 Post By MeefZah
post #1 of 9 Old 09-27-2018, 05:18 PM Thread Starter
vTwinDino's Avatar
Hello all!
I was on a trip last month and had a stupid tip over on a soft shoulder. The fall itself was nothing, but it was a royal pain to lift back up because the sandy shoulder didn't want to support the front tire. One of my attempts to get it up included trying to rotate the bike so that the front tire could land on the pavement instead, but I stopped when I realized I was moving the handlebar but not the bike :O
It's not a horrible bend, but it's something I'd like to correct over the off season.
My question is that I've already got Barkbusters installed to the OE bars, will it be problematic trying to get them installed to aftermarket bars (Renthal/Pro-Taper etc...) Or would it be easier/cheaper to just get an OE bar? I'm not very happy with the sweep angle of the OE bar and given how easily it bent I'd be interested in a stronger design, but if it means buying new Barkbusters, throttle tubes, grips etc... I'd be fine with sticking to the original.
Thanks!
-Dan
Sent from my Pixel 2 XL using Tapatalk
vTwinDino is offline
post #2 of 9 Old 09-27-2018, 07:02 PM
MeefZah's Avatar
I'd get some aluminum bars in the bend of your choice - the Pro Taper SE in ATV Mid bend are super popular here. The BB will work just fine on them BUT you will need to get new end hardware (about $12) because the aluminum bars have a thicker wall and less internal space than the OEM steel bars. Throttle and grip will transfer no problem and if the clutch side grip won't come off Oxford sells them separately for $20 so you can just buy a new one.
Edit, this post sorta explains why you need new end hardware, only going the opposite way - from aluminum bar mounts to steel bar mounts. The Tusk hardware is a good cheaper alternative and will work fine with the BB stuff:
https://www.stromtrooper.com/5246193-post2.html
Jeepster09 likes this.
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You canít grasp its vastness from a plane. Itís diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
MeefZah is offline
post #3 of 9 Old 09-27-2018, 08:53 PM
Jeepster09's Avatar
I agree with MeefZah. I put the pro tapers on for the strength and the better angles are a plus. I also added short adjustable levers to protect them from damage on a fall over.
Jeepster09 is offline
post #4 of 9 Old 09-28-2018, 08:58 AM
Highwayman2016's Avatar
If you go with the protapers you will need the inner clamps that are tapered for the Barkbusters too.
2014 650 Strom
Highwayman2016 is offline
post #5 of 9 Old 09-29-2018, 08:06 AM
MeefZah's Avatar
Not if he stays with 7/8" bars (Pro Taper SE). His existing inner clamps will work. The SE models are Seven Eighths.
Pro Taper SE ATV Mid with BB on my 2011 DL650:
MeefZah is offline
post #6 of 9 Old 09-29-2018, 11:22 AM
Jeepster09's Avatar
I also used the pro taper bark busters and eliminated the weights. No issues with vibrations for me. No special clamps needed.
post #7 of 9 Old 09-29-2018, 10:08 PM Thread Starter
vTwinDino's Avatar
Thanks for the advice guys! I'll be doing some measuring of the stock dimensions (on the not-bent side of course) to see what the difference would be. I also will check around if there's anyone in my area with different bars I could try out. Sounds like it will be a good winter project
post #8 of 9 Old 09-29-2018, 10:58 PM
Seems like a great excuse to upgrade since the oem bends are not optimal. Get the same diameter and I see no reason why all the existing accessories will not work. Given oem pricing, a new style bar might even be a little cheaper too
Houstrom46* is offline
post #9 of 9 Old 09-30-2018, 01:06 PM
Randolph's Avatar
I replaced my OE bars with HoleShots comfort bar a few years ago and still like them.
Had to ream the ends a bit to get the weights in. You can take a look at them here
http://www.holeshot.com/suzuki/dl/10...t-comfort-bars
Randolph is offline
Are there any simply Plug&Play aftermarket handlebars? nirontrip DL650A - 2012-2016 12 09-14-2018 06:53 PM
Took a spill - handlebars bent? JoshM DL650A - 2012-2016 15 06-11-2015 05:03 PM
Aftermarket handlebars closest to stock Borghi DL1000 from 2002-2012 10 01-15-2012 02:02 PM
aftermarket handlebars with Vstrom specific Barkbusters?? mpatch V-Strom Modifications and Performance 4 05-10-2011 11:41 PM
Aftermarket Handlebars? Vstromper West and Southwest 5 04-22-2009 12:08 AM
